PANASONIC SC-UA7 no 40V
  • matszal
    • Jul 2020
    • 12
    • Ireland
    Hi Everyone,
    I am trying to fix a speaker for a friend. I have some knowledge but not enough to fully diagnose the potential issue with it . I only get around 320V on C1224, no 40V.
    Tried to diagnose it as best as I could and there's no power on IC1201, positive gate voltage is needed to turn on the FET. VCC on pin 7 is missing and I don't follow schematic on how this is generated.
    Any ideas please.
    Full service manual can be downloaded from link below:
    https://elektrotanya.com/panasonic_s.../download.html
    Thank you!
  • CapLeaker
    Leaking Member
    • 8186
    Your PFC isn’t working cuz you only got 320V. I am just looking at this quickly. Figure out why the PFC isn’t working. Is it because the PFC is bad or is it because it doesn’t get turned on.
    • matszal
      • Jul 2020
      • 12
      • Ireland
      No voltage on PFC chip at pin 7. No short between pin 7 and pin 2. Not sure how to verify the chip.
      • CapLeaker
        Leaking Member
        • 8186
        Not sure what that brown goo on that PSU is… maybe nicotine? Wash it off. I think I see bad solder joints too. Look up the next page from your pic #2. Check things out on the top part of the schematic page 66. There is a fuse, ic1402, etc.
        for the PFC to work something needs STBY power first which is on all the time.
        • R_J
          • 9551
          For the pfc ic to work (and IC1501) it needs vcc which is supplied by D1405 and switched by Q1402, Q1402 is turned on by Q1405 optocoupler. the optocoupler is controlled by QR1601 from the PCONT1 line on CN1851
          As mentioned above, check F1401 fuse, if it is bad IC1402 is likely bad, if the fuse is good, check if you have any standby voltage on CN1851 pin9 or across C1601
          • matszal
            • Jul 2020
            • 12
            • Ireland
            Thanks R_J and CapLeaker, I am going to test it today and yes, that dirt is a nicotine and the smell is brutal. I will try one more time and if no joy I am going to trash it.
            • matszal
              • Jul 2020
              • 12
              • Ireland
              Fuse is good and 5V standby is present. On Q1402 I have 25V on Emitter and Base and Collector is 0V
              IC1402 voltages:
              1. 5.9V
              2. 1.05V
              3. 2.36V
              4. 11.1V
              5. 317V
              • matszal
                • Jul 2020
                • 12
                • Ireland
                Another update: (I was unable to edit previous post)
                No PCONT1 signal as I have power supply on my bench connected to mains and there's nothing else. Should I feed some voltage to QR1601 base?
                Guys, I am a total noob. I need to connect all the PCBs together in order to make all the tests valid.
                • R_J
                  • 9551
                  I would just short QR1601 Emitter to Collector, that should turn on the optocoupler and Q1402 to supply vcc to the rest of the circuit. I suspect the power supply is ok and there is a fault with the audio output circuit, if the processor senses a fault, it likely will not turn on the 35v for protection
                  • matszal
                    • Jul 2020
                    • 12
                    • Ireland
                    Thank you very much for your help, patience and advice. I spotted a bulged capacitors C2147 and C2148 on DAMP circuit. After replacing both the unit is working again.
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                      11-20-2024, 08:52 PM
                    • AquaMan Ua
                      by AquaMan Ua
                      05-17-2025, 09:40 AM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • aa10aa10
                      Panasonic Toughbook CF-33 mk1 BIOS repair
                      by aa10aa10
                      Good day,
                      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                      01-21-2025, 06:13 AM
                    • Mnawar27
                      Panasonic CF-H2AU24EF3 bios locked
                      by Mnawar27
                      Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                      I need help to remove it,
                      thankyou all.
                      SN; 2FKCA26876...
                      11-16-2024, 08:00 AM
