Hantol HPSU550. Worst power supply. Εver.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Hantol HPSU550. Worst power supply. Εver.
    Nice clean PCB layout, too bad it does not even have empty solder spots for the coils forming the Pi filter.
    Can you say cheap cheap cheap?
    (I remember seeing a PCB like this before, maybe was on Jonnyguru though)
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      Just saw this thread... my response is:
      I sure hope I don't buy one of these...
      • RJARRRPCGP
        • Jul 2004
        • 6304
        What a wimpy piece of @#$%! 200W max, unless you need a night light. Wimpy heatsinks, small I/P rectifiers, MJE13007-type switch transistors, wimpy O/P inductors and capacitors, 330uF I/P capacitors. 550W? Only if you are armored against shrapnel.
        The fake PPFC inductor probably is a way to dispose of scrap sheet metal while charging a few extra Yuan for the P/S.
        The heatsinks aren't even the worst thing!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • ddscentral
          • Mar 2008
          • 151
          • Lithuania, EU
          There's also a cement version.
          http://www.hardwaresecrets.com/blog/...-of-Cement/220
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
