Your spare PSU Stash
  • ratdude747
    replied
    Re: Your spare PSU Stash
    My only working spares are a handfull of 250W or less Clay Pigeons... I do have an early production (sorta) 450W TGGI (made by super flower) with all sorts of cool features. I also have a couple old 5V heavy 300W units (a Compaq badged delta and a hipro made AGI). All my good ones are dead (a 550W acbel, two 850W OCZ's, etc).
    dmill- I'm jealous... there's quite a few gems there (a 1200W no less!). The biggest I ever owned was a 950W Tuniq that I fixed and later sold to a classmate... kinda wish I had it, as if I ever upgrade my main rig's GPU's, I'll need more than the barely sufficient 600W in it now.
  • mockingbird
    replied
    PSUs currently with their PCBs out waiting for a re-cap (And they've been waiting for quite a while - until I make a big order from Neward):
    Click on attachment for higher res version.
  • dmill89
    replied
    My Stash:
    Mostly good stuff, listing below;
    PC Power & Cooling Turbo-Cool 1200W
    PC Power & Cooling Silencer 910W
    PC Power & Cooling Silencer 750W
    Enermax NoiseTaker II 600W
    Thermal Take TR2 RX (CWT) 550W
    Cooler Master (AcBel) 460W
    PC Power & Cooling Turbo-Cool 425W X2
    Antec Earthwatts (Seasonic) 430W (Re-capped)
    Antec SmartPower (CWT) 350W (Re-capped)
    Antec Basiq (FSP) 350W X2 (1 Re-capped
    HiPro 305W (Re-capped)
    Dell (Newton) 250W
    Compaq (Delta) 250W
    Rosewill (L&C) "400W" (Maybe 200-250W actually)
  • c_hegge
    replied
    Originally posted by everell
    I have collected so many that I had to store most of them in the attic!
    Wow! That's a lot. Now I'll have to go and find my bottom jaw.
  • Pentium4
    replied
    WOW! Nice stash! I want to see the other side with all the wires
  • goodpsusearch
    replied
    dafuq!
  • Agent24
    replied
    And I thought I had too many...
  • everell
    replied
  • c_hegge
    replied
    Originally posted by momaka
    Yup, that's me. But I think c_hegger confirmed it once, too.
    Nope, not me. I haven't load tested a Sirtec PSU from before they became Sirfa.
  • Agent24
    replied
    Maybe I don't read enough PSU reviews, but I think it would great if someone took an APFC PSU, measured it's efficiency, then removed the APFC and measured the efficiency again. Has this been done before? If yes, then I'd like to see that article.
    I haven't heard of it. But considering until recently most PSU reviews only went as far as to check voltages in the BIOS and sometimes with a multimeter too, I'd be surprised if anyone has done something that interesting.
    I'm sure someone here could give it a try, though.
    replied
    Originally posted by Agent24
    APFC might be more efficient but the APFC circuits are also more stuff to go wrong...
    All energy conversions have losses. In this case, APFC is just an extra conversion. So I'm not entirely convinced that APFC is more efficient. I think it's just that newer designs are more efficeint (i.e. single-transistor forward is better than half-bridge, then 2-transistor forward better than single-transistor, and etc.)
    Originally posted by Pentium4
    I should shouldn't I
    Might as well. If I ever come your way, I'll buy an entrance ticked .
    Maybe the caps are failing. Wasn't it you that said Sirtec PSU's have an insanely picky feedback loop?
    The Task PSU had 1 bad Jenpo cap on the 3.3V rail. But I replaced it, and that wasn't what caused the oscillation problem. I didn't experiment too much with it, but I remember (from a while back) that it didn't like it if you added an extra cap on the 12V rail (it has spots for 2x 10 mm caps, but only one is used and is usually 1000 uF... the other was 100 uF - yes, just one hundred uF). And although it seemed to be only stable with the stock setup, even then the regulation was quite bad.
    Originally posted by goodpsuseach
    Can you upload label and internal photos of that psu please?
    I'm waiting for a sunny day...
    No, actually the problem is that I am too slow and too lazy and never get things done on time, so I never get to post all of that stuff on BCN. I actually have the pictures already.
    ... unfortunately, yes, you have to hit me on the head for me to do anything right
    But I promise you I'll do it someday. I really want to as well.
  • Pentium4
    replied
    Going for The PSU Museum title?
    The Task PSU is built by Sirtech, but it has very crappy regulation and oscillates BADLY with a 12V load.
  • goodpsusearch
    replied
  • Pentium4
    replied
    As long as it's not a lump of Chinese concrete!
    Haha so true usually those aren't reliable though
  • Agent24
    replied
    I like an old reliable design with PPFC
  • c_hegge
    replied
    Here, on 230V, that's not an issue, as the coils don't get as hot.
  • Pentium4
    replied
    So true. It seems that the booster coil is the most likely thing to fail in a APFC circuit. With proper placement, I like an old reliable design with PPFC
  • Agent24
    replied
    replied
    I have way too many...Either to have on hand, waiting to sell, or just laying around because I recapped it
    I have mostly junk. Just a few good worthwhile units. Namely, a MPT-301, a HiPro HP-P2507F3P tank in a RaidMax RX-380K case , Bestec ATX-1956D, a Morex MXA-235PTF1, and a LiteOn 250W unit (forgot model).
    I also have a PowMax LP-6100D and a Task TK-930TX. Not sure if I should consider these as decent, though. The PowMax... well, it's a PowMax, need I say more. I wouldn't trust it even with a recap and a proper 5VSB circuit. The Task PSU is built by Sirtech, but it has very crappy regulation and oscillates BADLY with a 12V load. I think a Deer DR-250ATX that I found last year is better than both of these. At least I know I can trust it up to 250W and it will have good regulation.
    Originally posted by japlytic
    as many of the "old-school" designs... are not worth anything to me (other than parts).
    Why?
    There are so many excellent "oldschool" designs without PFC. Just because they lack PFC doesn't mean they are inferior. In fact, many of the better ones (think OEM Delta, HiPro, and Lite-ON) are simple, yet bullet-proof tanks, especially with good caps.
    I think you are missing out.
  • Pentium4
    replied
    I decided to only keep units with active PFC
    How come?
    I've got a couple of boxes of PSUs like that. Need go through and weed out the good ones and test them. The crappy ones I am keeping for spare parts and projects.
    Pictures?
    HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
    This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    09-06-2024, 08:50 AM
  • objecttothis
    EVGA 430W PSU Correct voltages but computer won't turn on
    by objecttothis
    I had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
    02-08-2025, 11:19 AM
  • SurrealMustard
    Every other column of red pixels won't display on Sony KDL-52XBR9 LCD
    by SurrealMustard
    It's been a while since I've run into this before, so I could use a little help. The attached image is a close-up of a solid white screen. What I'm seeing is red-green-blue-black-red-green-blue instead of red-green-bue-red-green-blue.
    I haven't cracked into the thing yet, but before I do, has anyone encountered anything like this before? If so, what was the solution? T-Con? Ribbon connections? Something else?
    01-31-2025, 06:39 PM
  • Topcat
    Rebirth of a Pentium II - P6DKF Retro Build
    by Topcat
    It's been a LOOOONG time since I've done one of these.... I've had the case for years, its just been sitting in my office with crap stacked on top of it. It has a Micronics 486 motherboard in it with a DX4-100 CPU.... I was never a 486 enthusiast, I had no intentions of doing a build with it....I only kept it for the case....which someone dropped off for recycling years ago.
    Anyway, I recently stumbled upon a Supermicro P6DKF AT motherboard and tested it in 'the oven'. I remember seeing one (or one similar) back in the 90's before eATX was a twinkle in anyone's eyes and wondering...
    03-25-2023, 09:20 PM
  • shovenose
    Spare Parts + eBay's Finest = Worst Gaming PC of 2021?
    by shovenose
    Alright folks, today I present my latest "build", consisting of mostly spare parts with a few things off eBay.
    Parts List and Pricing
    CPU: 3/0GHz 4C/4T Intel Core i5-7400. Nothing exciting here, got it off eBay for $80.
    RAM: 16GB (2x8GB) Corsair DDR4-2400. Had it floating around. Free.
    Motherboard: Gigabyte B250M-Gaming 3. Because I had it floating around and the model number contains gaming so it must be better, right? Free.
    Storage: 240GB WD Easystore SSD. As far as I know, it's just the Best Buy rebadge of...
    12-21-2021, 08:34 PM
