Is it standard practice to change the wireing on the power supply connecters?
  • brbpab94
    • Mar 2007
    • 22
    I just bought a MSI K7N2 Delta2 motherboard and I have a cooler master power supply #RS-430-PMSR.I don't think the wires are in the right places because the 4 pin connecter is suppose to have 2 12v and two grounds and it has one black wire one yellow wire one red wire and one orange wire.I'm no rocket scientice but I think thats wrong.
    Please help.
    Brian
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Is it standard practice to change the wireing on the power supply connecters?
    Does it not snap onto the 20 pin atx connector then to make it a 24 pin connector?
    • brbpab94
      • Mar 2007
      • 22
      yes it slides into the conecter but the manual for the mother board says the four pin conecter is suppose to have 2 12v and 2 grounds.I have 1 ground 1 red wire which is 5v one orange wire which is 3.3v and one yellow wire which is 12v coming from my power supply.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        I did not mean slide into the connector on the mainboard
        I meant is it not possible to attach it to your ATX 20 pin connector to make that connector an ATX 24 pin connector?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          dig into the tangle of plugs to find the p4 power
          the one you describe is to be clipped onto the 20 pin to use on 24 pin boards.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            why not post a pic?
            • Tom41
              • Oct 2005
              • 338
              • England
              If in doubt, find some way of powering up the PSU without connecting it to a motherboard (use spare HDDs, CD-ROM drives etc. for load), and measure each pin's output with a multimeter. If the voltages you get in each place differ from the ATX specification, the wiring is indeed different!
              I have a PSU like that; it was a non-standard shape, and used to power an HP Vectra P166 machine. Although it used an ATX-style connector to bring power to the motherboard, the pinout was different... enough to cause smoke if you connect to the 'wrong' board! I posted pictures of it in the PSU Build Quality Pictorial topic.
              You know there's something wrong when you open your PC and it has vented Rubycons...
              • bgavin
                • Jan 2007
                • 1355
                Somebody mentioned that Dell uses non-standard pinouts on some of the PSU... dunno, but that is scary.
                • Spacedye69
                  • Nov 2005
                  • 698
                  • US
                  I have a semi on topic question. What is the difference between the "new" 24 pin connectors and the "older" 24 pin for servers?
                  • pentium
                    • Mar 2006
                    • 2778
                    Hey how reliable is that board and what speed do you have it at right now?
                    I have one in my system and it's being a real dog.
                    Find Nedry!
                    Check the Vending machines!!
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                      03-31-2024, 02:12 PM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
                    • madan1
                      555 based power supply getting too hot
                      by madan1
                      Good day.
                      I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                      The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                      After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                      When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                      06-23-2025, 04:38 PM
