Antec TruePower Trio 430W
  • Ark42
    • Apr 2004
    • 43
    The one I just put in my system to replace the Antec TruePower 2.0 480W, was just removed after only a few short weeks to make room for the SeaSonic S12-430W.
    I cracked open the Trio 430W to find Teapo, Ce-Tur, and RLX brand caps in there. Teapo I already know is a bad brand from my Epox motherboards in the past.
  • Rainbow
    • Aug 2005
    • 1374
    Re: Antec TruePower Trio 430W
    You're lucky as there are no Fuhjyyus.
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Looks like great caps for an Antec. Not too excited about the Pce-turd, though.
      • geforcefly
        • Jul 2006
        • 33
        If I'm not mistaken, those are the same brands of caps that I saw in an Antec SU-380 PSU (comes with the Fusion case) that I found in a dumpster just a few days ago (it was dead). The caps that have RLX on them are OSTs.
        • Ark42
          • Apr 2004
          • 43
          Is there a quick reference of good/bad brands? There are so many, I forget which are well known after a while.
          I remember Fuhjyyu from that other Antec I just pulled a short while back (also posted about here) Those were already bulging after only ~8 months.
          • starfury1
            • May 2006
            • 1256
            For bad caps or good caps brands, check forum stickies here
            For PSU's Not that I know of here, in one place (I could be wrong)
            The other prob is that same design can have different brand caps used at an earlier or later stage of production
            Different models in the same brand can fall into a good or bad also
            So you probably want 3 categories....for PSU
            1) good design with good Caps
            2) good design with junk caps
            3) just plain rubbish
            1 worth buying
            2 worth refurbishing
            3 look out dumpster here I come!
            cheers
            • rabbituk
              Antec TruePower 380p failed after intermittent supply, suspect MOV
              by rabbituk
              I have an Antec TruePower 380p PSU that I had repurposed from a Sonata case. It had been working fine on a server in the loft using the Wake-on-LAN feature regularly until a couple of recent power outages where the power became very unstable - going on/off very quickly. There is now no output whatsoever from the PSU & fan isn't working. There was a pop when I attempted to turn it on.
              Upon examination, it appears that voltage isn't getting very far so I believe the immediate issue is within the first stage. There is a green component that I am not familiar...
              12-01-2020, 03:26 AM
            • iMic
              IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
              by iMic
              Hi folks,
              I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
              The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
              11-29-2023, 06:44 AM
            • AureliaKitsune
              Request for Boardview – RX 6900 XT MSI GAMING Z TRIO
              by AureliaKitsune
              Subject: Request for Boardview – RX 6900 XT MSI GAMING Z TRIO
              I am looking to repair my MSI RX 6900 XT GAMING Z TRIO graphics card and need the boardview to perform an accurate diagnosis.
              Would it be possible to provide it to me or let me know where I could obtain it?
              Thank you in advance for your help.
              Best regards,
              Aurelia...
              02-06-2025, 02:21 PM
            • duxzero
              Request: MSI Radeon RX 6900 XT Gaming Z/X Trio schematic and boardview
              by duxzero
              Does anyone happen to sit on schematic and / or boardview files for MSI Radeon RX 6900 XT Gaming Z/X Trio? The layout is a bit too different from the reference card and the Asus/Asrock/Gigabyte schematics/boardview files that are out there.
              04-24-2025, 12:23 PM
            • objecttothis
              EVGA 430W PSU Correct voltages but computer won't turn on
              by objecttothis
              I had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
              02-08-2025, 11:19 AM
