What maybe causing this Chopper to short ?
  • SM-Piyes90
    • Feb 2014
    • 120
    • Morocco
    #41
    Re: What maybe causing this Chopper to short ?
    Hi again am back on topic again .
    I just want to point out the solution for my original problem with the welder
    I have used original IGBTs from fairchild and they have worked without getting shorted , i guess i was using counterfeit components ( big mistake ) .
    • Agent24
      I see dead caps
      • Oct 2007
      • 4938
      • New Zealand
      #42
      Yeah, that would do it. Power transistors are very often fake from China (Usually they use a lower-rated part and relabel it)
      -David VanHorn
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Great page on fake transistors!
        http://sound.westhost.com/fake/counterfeit-p2.htm
        Usually the silicon die is too small, and can't handle the power that the bigger ones can. Sometimes the labeling looks strange.
        Muh-soggy-knee
          • 30951
          did you check the flyback transformer?
          • Agent24
            I see dead caps
            • Oct 2007
            • 4938
            • New Zealand
            #45
            This might help you: http://www.repairfaq.org/samnew/tvfaq/tvhorkboeh.htm
            Also check through the whole document for general CRT TV information http://www.repairfaq.org/samnew/tvfaq.htm
            -David VanHorn
            • DynaxSC
              Extreme High Current & Low Voltage Short Killer ??
              by DynaxSC
              Hi Folks
              I'm looking for a extreme high current short killer solution for a reasonable cost.
              I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
              After taking off the socket, the shorts dissappear again.
              The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
              10-15-2024, 10:13 AM
            • Stephen
              MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
              by Stephen
              I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
              02-06-2025, 12:03 PM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • spleenharvester
              Reverse engineering of DoCreate DHJ567 handheld spot welder
              by spleenharvester
              Hello everyone
              I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
              Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
              05-08-2025, 02:52 PM
            • evilkitty
              Flux causing high resistance short?
              by evilkitty
              Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
              Temp is on the left humidity is on the right
              i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
              The pin out looking down from the top is (note this is common cathode)...
              07-17-2024, 09:38 AM
