How to remove protections from SG6105?
  • m111920
    • Nov 2013
    • 49
    • Croatia
    I want to remove all protections from SG6105 powered ATX PSU,
    I have removed all wires except +12v and I will use this PSU for powering 12v stuff
    I want to remove protections and everything because PSU won't work without proper voltage on vsense pins.
  • 999999999
    • Sep 2006
    • 774
    Re: How to remove protections from SG6105?
    Normally a person would put a dummy load on the 5V rail to keep it from drifting to an excessively high voltage, something like a 2 ohm, 20W power resistor on a heatsink.
    That controller chip has a built in voltage divider so there isn't an external one that could be modified as with some designs. Instead you must give it a fake reference voltage and since it will be regulating based on 12V rail load, that is the rail you would use for the fake reference.
    What you can do instead is sever the signal line leading to the controller V5 pin, the one which senses 5V rail voltage. After that line is cut, use a resistor divider circuit from the 12V rail to cause 5.0V to be sensed when the 12V rail is 12.0V.
    See the following page which is a voltage divider calculator. http://www.calculatoredge.com/electr...e%20divide.htm Ra resistor would go in series from the 12V to the controller signal pin V5 and Rb would go from
    a point between Ra and V5 pin, to ground.
    You can input the 12V source "Vin", 5V output "Vout", then pick a few thousand ohms resistor for "Ra" and it will tell you the "Rb" value you need. It is up to you to determine if you have acceptable resistor values at high enough precision to get close enough to 5.0V. For example if you had a 6K8 (6800ohm) "Ra" and a 4K7 "Rb", you would get close to 4.9V. If that is close enough you are done. If it is not close enough you need to use a little lower value "Ra" with a high precision rating, something less common so sources from an electronics supply house.
    If after doing the above for the 5V rail sense circuit you find that it still needs the same done for 3.3V, repeat all the above for that rail and V33 sense pin, to divide voltage down from 12V to 3.3V.
    • m111920
      • Nov 2013
      • 49
      • Croatia
      Isn't there a way to disable it completely as SG6105 is TL494+ two 431 in one chip.
      I have already removed 3.3v and other components and I don't want to solder it back
      TL494 is very simple, just unsolder a few pins(13, 14 and 15 i think) from board and protection is disabled..
      • 999999999
        • Sep 2006
        • 774
        I wrote nothing about adding back 3.3v. On the contrary you are to sever the 3.3V and 5V, effectively getting rid of both then using a voltage divider between the 12V rail and each detection pin.
        You are welcome to try doing whatever you can think of instead of my suggestion. I did not read the entire datasheet, only enough to come up with the potential solution I mentioned.
        • 999999999
          • Sep 2006
          • 774
          Edit for more clarity:
          I wrote nothing about adding back 3.3v. On the contrary you are to sever the 3.3V and 5V traces leading to their respective voltage sense pins on the controller, effectively getting rid of both so you don't need the components specific to those rails any longer, then using a voltage divider between the 12V rail and each detection pin to lower the 12V to 3.3V at the 3.3V detection pin and lower 12V to 5V at the 5V detection pin.
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • unimatrix93
            Which resistor should I remove/replace to decrease current to backlight leds?
            by unimatrix93
            Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
            However I need some help identifying the resistor I need to replace to achieve this.
            Thank you!
            11-29-2024, 05:05 AM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
