Macbook Pro 14 2021 - A2442 - 820-02098-A not turning on 5v fluctuation
  • Rickkap
    • Aug 2015
    • 139
    I would like some help with this MacBook if possible. It came in with not turning on and the Magsafe light was off. After inspecting the logicboard i cannot find any liquid damage and also no burnt or shorted components.
    took some measurement and i can see i have fluctuation on PP3V3_S2 and also PP5V_S2_MAIN amongst other rails. Using the thermal camera RC282 & RC283 were pulsing, but after removing these it was still the same.
    I then did some investigation into why the rails were pulsing and noticed that P5VS2_PWR_EN (comes from U8100) is also doing the same thing.. Replaced both U8100 and also U7700 from a working (iCloud locked) logicboard, still the same. I've also temporarily removed all the components on the PP3V3_S2 rail but the fluctuation is still there so i'm thinking that it could be coming from a higher rail. I'n not sure what the power rail startup sequence is on this model. All the AON rails are fine and stable and now i've hit a wall and not sure what to do next.
  • Rickkap
    • Aug 2015
    • 139
    Anybody willing to help!!!
    • mon2
      • 14685
      Check the frequency of MPMU_XTAL2 and MPMU_XTAL_R.
      • spidertnt
        • Jul 2016
        • 34
        https://www.badcaps.net/forum/troubl...no-power-a2779
        sometimes failed caps repeat ...worth a check
        • Rickkap
          • Aug 2015
          • 139
          Click image for larger version  Name:	17320307096611825669491477237956.jpg Views:	0 Size:	1.28 MB ID:	3510653
          32Khz and stable on both sides of R8350
          • mon2
            • 14685
            What is the voltage and current draw of the USB Type C meter?
            • Rickkap
              • Aug 2015
              • 139
              It's 5.18v current draw fluctuates between 0.00 and 0.05A and that's on all 4 ports
              • mon2
                • 14685
                Each PD controller is a suspect. Confirm the LDO rail of each controller - much like the CD3215 article:
                https://logi.wiki/index.php/CD3215_Bootup_Sequence
                The BMC 1v1 will only be active for the USB C port being used to power the board.
                • Rickkap
                  • Aug 2015
                  • 139
                  My understanding is that these boards don't have the T2 and are not similar to the CD3215. I took it upon myself to swop from an icloud locked board, all 4 CD3217 in the correct order along with the ROM's as explained on this page https://logi.wiki/index.php/CD3217_a...er_on_Sequence and it is still fluctuating.
                  I've spent enough time on this now so it's become another donor or until someone else gets and fixes the same issue.
                  • mon2
                    • 14685
                    https://boards.rossmanngroup.com/thr...acement.64959/
                    • nhosic
                      • Apr 2016
                      Rickkap, have you found any solution to this one? I have the same exact issue here. Spotless board. Pulsing RC282 and and RC283. My thinking was the same as yours. Start replacing ICs around the 5V_S2 and 3V3_S2 lines, but I don't want to waste time if this isn't the issue.
                      • mon2
                        • 14685
                        Remove all power. Meter in resistance mode. Measure the resistance to ground of PP5V_S2_MAIN @ LC260 (either side). What is the resistance in ohms?
                        • nhosic
                          • Apr 2016
                          I can't find any lines not shorted to ground at all - the board looks spotless. Diode mode is .342 on each side. Resistance to ground is 5 megs.
                          • mon2
                            • 14685
                            What is the voltage to ground of P5VS2TPS_PWR_EN (measure @ RC260)? This is the ENABLE signal for this power rail that is absent.
                            • nhosic
                              • Apr 2016
                              0.7 volts
                              • nhosic
                                • Apr 2016
                                I'm wondering if U8100 just kind of fried because it is responsible for a lot of these smaller power rails, just don't want to harvest and reball such large BGA chips for no reason.
                                • mon2
                                  • 14685
                                  Carefully measure the voltage to ground of:
                                  SMBUS_BATT_SCL
                                  SMBUS_BATT_SDA
                                  • Rickkap
                                    • Aug 2015
                                    • 139
                                    I never found the solution for this problem, i did think it could be the SOC which was faulty and in the end i gave up. I must have replaced so many components but it wouldn't stop fluctuating. If i was you i wouldn't bother try to fix it, plenty of man hours wasted
                                    • modtool
                                      Macbook Pro 14 2021 - A2442 - 820-02098-A - Internal display not turning on but MacOS working good
                                      by modtool
                                      Dear collegues,
                                      the owner of this machine brought it to me saying that suddenly one day the display didn't turn on anymore, he tought that all the machine was damaged but it turned out that the MacOS starts good and stays on, and that connecting it to an external display it works without problems.
                                      If you take a look into general settings, you can also see that the internal retina display is recognized as connected by the main board but for an unknown reason it doesn't turn it on.
                                      I've tried to put a bright light towards the screen but I can't see anything, any shadows or apple...
                                      05-08-2024, 05:50 AM
                                    • dbuergi
                                      Macbook A2442 no display board 820-02098
                                      by dbuergi
                                      i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
                                      So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
                                      05-25-2025, 10:58 AM
                                    • TechSplendid
                                      MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                                      by TechSplendid
                                      Hi All,
                                      I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                                      Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                                      04-09-2025, 02:13 AM
                                    • tyler_jones8209
                                      2021 M1 MacBook Pro (A2442/820-02098-A) Stopped Charging on All Ports
                                      by tyler_jones8209
                                      So my friends A2442 MacBook Pro stopped charging one day and hasn’t worked since. It wasn’t like an immediate shut off, like it worked until the battery died but now she can’t charge it so idk what to do with it.
                                      I don’t have an ammeter (yet it’s coming soon) so idk if it’s doing anything funky with current or voltage but I know it doesn’t charge on ANY of the ports.
                                      I took it down to the motherboard hoping to see an obviously bad component but everything looks good.
                                      I don’t have much experience with laptops, only consoles and controllers...
                                      10-28-2025, 04:54 PM
                                    • gurpawan
                                      A2442 14inch Macbook Pro ,JR940 Connector- where to buy?
                                      by gurpawan
                                      Hi, can anyone please advise on where to buy the JR940 microphone flex connector? I accidentally broke it while repairing A2442 14inch Macbook Pro 2021. it came off....
                                      10-22-2025, 02:40 PM
