Delta Serverpower 450W Ex (CAA-450BT A). Was browsing the Web on my Ivy Bridge system when there was a loud pop from the power supply and the system shut down. I do not recall any smoke coming from the unit. I took it apart but there is no sign of damage. I think only the fuse blew. I would like to identify the problem that caused the fuse to blow. Any ideas? It has only been in use for less than two years.
Delta Serverpower 450W Ex (CAA-450BT A) went pop...
Re: Delta Serverpower 450W Ex (CAA-450BT A) went pop...
Check the transistors on the primary side heatsink. (near the two big capacitors)Delta Serverpower 450W Ex (CAA-450BT A). Was browsing the Web on my Ivy Bridge system when there was a loud pop from the power supply and the system shut down. I do not recall any smoke coming from the unit. I took it apart but there is no sign of damage. I think only the fuse blew. I would like to identify the problem that caused the fuse to blow. Any ideas? It has only been in use for less than two years.Muh-soggy-knee -
also some resistor and caps near the transistor. that is more likely failed when transistor is defect."There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
Maybe check to see if one/both of the MOVs across the big lytics shorted.PeteS in CA
****************************Comment
…or opened. Don't see any thermistor so you can probably skip it, if there is some, check it as well.Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
by corrizeHello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping... -
by JunkrepairI'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
I found this nice little description of the conversion:
Calculating capacitor ESR from Tan(delta)
https://forum.digikey.com/t/calculat...-from-tan/2633
It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...-
Channel: General Capacitor Questions & Issues
This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 06:11 AM
This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
- Loading...
