pins for turn on fsp123-3f01 power board
This topic has been answered.
  • spantor
    • Jan 2020
    • 46
    • spain
    Hi.
    Could someone tell me which pins to jumper to activate Power board fsp123-3f01. It is from a Grundig TV model 49 vle 6621 wp
    Thanks un avance
    Click image for larger version  Name:	IMG20240302121341.jpg Views:	0 Size:	2.45 MB ID:	3227247
  • Answer selected by spantor at 03-05-2024, 02:41 PM.
    kasfamily
    • Aug 2014
    • 772
    • Russia
    yes-Pins 110vac and 50vac should be measured in alternating current.
    If 5 volts do not appear on pin BL, then there is a problem on the motherboard.
    to check the operation of the backlight inverter, connect pin 5v with pin BL via a resistor with a nominal value of about 1 kOhm
    • spantor
      • Jan 2020
      • 46
      • spain
      Some body can help me?
      • kasfamily
        • Aug 2014
        • 772
        • Russia
        Hi, measure the voltage at STBY to start
        • spantor
          • Jan 2020
          • 46
          • spain
          There is voltage on standby pin. Only in 5v pin. I don't know if it is normal or if there is some anomaly on this board​
          • kasfamily
            • Aug 2014
            • 772
            • Russia
            pin 5V =5v
            pin STBY = how many ?
            • spantor
              • Jan 2020
              • 46
              • spain
              pin 5V =5v
              Apologies, I mean there is no voltage on STBY. I don't know if this situation is normal​
              • spantor
                • Jan 2020
                • 46
                • spain
                • kasfamily
                  • Aug 2014
                  • 772
                  • Russia
                  When you turn on the TV with the remote control, how does the voltage on the pin STBY change?
                  • spantor
                    • Jan 2020
                    • 46
                    • spain
                    standby has around 3v when I turn on the tv.The problem is that the standby leds make 2 flashes and then the TV turns off.When TV tries to turn on there is no any image and there is no back light, however there is 90v in the LED backlight + cable but there is no - in the LED backlight cable.I have my doubts about using this power board, for that reason I want to turn on this power board without the main board connected
                    • kasfamily
                      • Aug 2014
                      • 772
                      • Russia
                      Ok
                      How does the voltage at the pin BL change when you turn on the TV using the remote control?
                      • spantor
                        • Jan 2020
                        • 46
                        • spain
                        Ok
                        There is -5.31voltage between pin bl and gnd when I turn on the TV. Then the voltage disappears definitively at the end of the cycle of the two flashes of the standby LED
                        • spantor
                          • Jan 2020
                          • 46
                          • spain
                          This board have another board for leds
                          • kasfamily
                            • Aug 2014
                            • 772
                            • Russia
                            where do the pins DIM0,1,2 go?
                            • spantor
                              • Jan 2020
                              • 46
                              • spain
                              Dim 0.... 0v
                              Dim 1..... 0v
                              Dim 2.....1,6v.
                              • kasfamily
                                • Aug 2014
                                • 772
                                • Russia
                                In the last photo, the pin table CN2 is not completely visible.
                                • spantor
                                  • Jan 2020
                                  • 46
                                  • spain
                                  • spantor
                                    • Jan 2020
                                    • 46
                                    • spain
                                    The measurements I have made so far have only been in cn3
                                    • kasfamily
                                      • Aug 2014
                                      • 772
                                      • Russia
                                      you need to check the serviceability of the backlight, apply a voltage of 200 volts with a current limit of 250 mA, red wire is positive, yellow is negative
                                      • spantor
                                        • Jan 2020
                                        • 46
                                        • spain
                                        Bl work
                                        • kasfamily
                                          • Aug 2014
                                          • 772
                                          • Russia
                                          ok
                                          how many volts when turning on the TV on S2001 between pin1 and pin4
                                          • Destroyer-Br
                                            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                            by Destroyer-Br
                                            I'm working on an Acer Nitro 5 unit with the following specs:
                                            • Motherboard: LA-J871P Rev: 1B
                                            • Model: Acer AN515-55-59MT
                                            • S/N: NHQ7JAL00403906A973400
                                            • SNID: 03902728734
                                            Initial Issue
                                            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                            04-17-2025, 08:18 PM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
