pins for turn on fsp123-3f01 power board
This topic has been answered.
  • spantor
    • Jan 2020
    • 46
    • spain
    Originally posted by kasfamily
    ok
    how many volts when turning on the TV on S2001 between pin1 and pin4
    there is no voltage. but there is voltage between positive pin and chassis. there is 190v. negative pin does not close the circuit
    • kasfamily
      • Aug 2014
      • 774
      • Russia
      then you need to measure the voltages at all pin S2000 when turning on the TV
      • spantor
        • Jan 2020
        • 46
        • spain
        • spantor
          • Jan 2020
          • 46
          • spain
          • spantor
            • Jan 2020
            • 46
            • spain
            Originally posted by spantor
            apologies I think VAC voltage I have measured with continuous voltage. I will measure again
            • kasfamily
              • Aug 2014
              • 774
              • Russia
              #26
              There is -5.31voltage between pin bl and gnd when I turn on the TV. Then the voltage disappears definitively at the end of the cycle of the two flashes of the standby LED
              Why on S2000 pin BL=0, to turn on the backlight there should be about +5 volts
              • spantor
                • Jan 2020
                • 46
                • spain
                #27
                I can confirm that between pin bl and pin gnd there is no voltage when turning on the tv.
                Pins 110vac and 50vac should be measured in alternating current? I thought that VAC refers to alternating voltage current
                • kasfamily
                  • Aug 2014
                  • 774
                  • Russia
                  #28
                  yes-Pins 110vac and 50vac should be measured in alternating current.
                  If 5 volts do not appear on pin BL, then there is a problem on the motherboard.
                  to check the operation of the backlight inverter, connect pin 5v with pin BL via a resistor with a nominal value of about 1 kOhm
                  • spantor
                    • Jan 2020
                    • 46
                    • spain
                    #29
                    I think I can rule out PB. The easiest thing will be to buy a used MB and wait for luck. Thank you for all your patience and knowledge. If I can help you with anything, don't hesitate to ask me.
                    • kasfamily
                      • Aug 2014
                      • 774
                      • Russia
                      #30
                      Ok.
                      Check the voltage on the PFC capacitor in the power supply - it should be about 400 volts.
                      Check all voltages DC/DC on the motherboard.
