Niky 1000 UPS making strange sparking noises (video)
  • GraphicMan
    • Aug 2018
    • 124
    • Egypt
    anyone can explain what and why is this sound "ezz ez ez zzz" clearly starting from 0:34, the ups is niky 1000, i am using 7s6p good lithium 18650 cells pack, that sound only appear when i load any pc or lcd or crt, but never ever when using even much higher load 200w tungsten bulbs, althogh the sound, it never shut down nor give a warning and the pc or lcd or crt works completely normal at all times, in the video u can notice that the bx100 (voltmeter) is restarting with the sound, also the bulb flickers with the sound, i have checked only the largest cap on board (which is not that big) and it was 50v 1000uF and i found it ok, i am really curious to know the reason of that sound, if the battery is full it does not make the sound unless the INDUCTIVE load is too high, weak battery with high but resistive load (bulbs) no sound at all!!
    at the end of the video i added a bulb along with the pc and lcd, u can see how the bulb flickers with the sound, when i turned off the pc and lcd the sound is gone and the bulb is not flickering also. what could it be, it is not of a high load at all because no matter how high load but only bulbs it is fine, the pc and lcd used are both no more than 80watts max together, the bulb is 100w, and i used 2 of them with no issues at all for a very long time.​
    • Jul 2011
    • 6040
    Where is the video clip that you are talking about
    • CapLeaker
      Leaking Member
      • 8190
      that niky 1000 sparking .mp4 file under the pictures.
        • 31061
        make it happen in the dark with the cover off - look for the spark
        also, it's probably leaving a burn mark so it should be visible
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          where ? Click image for larger version
Name:	Screenshot from 2024-02-29 01-28-40.png
            • Jul 2011
            • 6040
            The same question I have unless Safari is blocking it
            • GraphicMan
              • Aug 2018
              • 124
              • Egypt
              this is so strange i am sure the video was there when i posted, now me also dont see it, what to do?
              guys it is NOT sparking, it is making a similar noise like sparking, i have already checked it in the dark, no sparking
              btw a local technical that i dont know told me to replace the resistor of the frequency! as well as the orange ceramic cap, does that help? we need the video though!
              • CapLeaker
                Leaking Member
                • 8190
                There!
                  • 31061
                  if it's not sparking then it may be an inductor / coil vibrating
                    • Jul 2011
                    • 6040
                    Here is a screenshot of the picture selection
                    • CapLeaker
                      Leaking Member
                      • 8190
                      weird. I can see it on my Ipad using Edge. I think your problem might be that you are not logged in. Not logged in = no attachments. Just tried it with Safari. Not logged in and my screen looks like yours. Log in and then you see the link.
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        i am logged in and cant see it
                        • harp
                          • Jun 2022
                          • 604
                          • Planet Earth
                          To confirm for clarification attachment issue
                          Attachment are see either logged or no logged status, but to download you must be logeed in.
                          When op posted I see for sure mp4 file listed on bottom, while logged/no logged, but next day mp4 is disapeer, not listed anymore while loged/nologed... and there is no notice left of there is any "last edited"...
                          I check from two different browser.
                          So...
                          I suggest to use external service till no resolving attachment issue
                          http://fileconvoy.com/
                          I have tested this and using it for few years, it is wery good, work with old browser also.
                          Just set expiration date to two-three weeks, and post link here...
                            • Jul 2011
                            • 6040
                            I downloaded edg and it still not there and I am logged into it this is how I doing this post reply
                            • CapLeaker
                              Leaking Member
                              • 8190
                              sam_sam_sam, harp
                              funny… for me it is still there, just like the pic I posted earlier. That’s strange… not sure why I can see this file and you guys are not.
                              • harp
                                • Jun 2022
                                • 604
                                • Planet Earth
                                Maybe you see a your stored memory, browser cache...
                                Can you post the link for dl... maybe is only not published but still there bug?
                                • GraphicMan
                                  • Aug 2018
                                  • 124
                                  • Egypt
                                  Logged in or not, i have never seen the mp4 attachment also until now after i have posted it, nor got any notification for removal, also the reply mail notifications comes so late, so these are 2 issue for the admins to check
                                  here is a link for the video, plz guys help
                                  https://drive.google.com/file/d/1Xk7...ew?usp=sharing
                                  this sound is not normal and it does not appear unless there is an inductive load, resistive loads like heaters or tungustin bulbs never do that, it is not by chance, many times if the battery is full and the inductive load is low it can stay up to 30min without this sound
                                  • GraphicMan
                                    • Aug 2018
                                    • 124
                                    • Egypt
                                    oh now i see the original video link attachment for the first time after posting!
                                    if u still dont see the attachment plz use the google drive link instead , plz read the post details to understand what is going on on the video, thanks
                                      • Jul 2011
                                      • 6040
                                      I have a question for you dose do the same thing when you use the batteries that are suppose to be used are they 2 @ 12 volts each which is 28 volts and 2 12 volt batteries are 24 volts unless I am mistaken you might be putting too much voltage on the battery backup circuit which might be causing the issue
                                      When did this too a battery backup that was 24 volts I could only use 6s 2P because of the voltage when the batteries are fully charged
                                      • GraphicMan
                                        • Aug 2018
                                        • 124
                                        • Egypt
                                        i dont have SLA anymore, i dont think this has to do with the battery wutsoever, the battery is charged with the ups, so it stops charging everytime exactly at 27.3v, and at any voltage the ups will make so IF the same type of load is used, on bulbs it never do that at any voltage and any load, so apparently it is related to the type of load and not the battery, on top of that, regardless where is the sound coming from? the transformer or something else, it seems like the transformer humming is continuous and the sound is extra (not replaced)
                                          HP EliteBook 1050 G1 + LG SJ2 Bluetooth Sound Bar Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + LG SJ2 Bluetooth Sound Bar Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + LG SJ2 Bluetooth Sound Bar boardview and 1050 G1 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-06-2024, 02:34 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • repair-it
                                          TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                          by repair-it
                                          I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                          Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                          10-11-2023, 07:18 PM
                                        • ezenia
                                          LUMIMAN Smart Bulb IC ID?
                                          by ezenia
                                          I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                          In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                          04-28-2025, 05:56 PM
