Niky 1000 UPS making strange sparking noises (video)
    • 31304
    most invertors wont charge a bettery with no charge, so using a load wont work,
    they also dont stop charging - they switch to tricklecharging al low current.
    back to the problems,
    transformers hum because they can move - tightening any bolts and maybe putting wax or epoxy on the windings can reduce it.
    ticking or clicking could be a loosly wound inductor.
    • petehall347
      • Jan 2015
      • 4451
      fizzing sound sounds like something that is damp or wet arcing . . not saying that's what it is but sounds just same
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        If there is arcing, you would think it should show on the PFC.
        • GraphicMan
          • Aug 2018
          • 124
          • Egypt
          it does a float charging and lithium cant take more voltage by giving more current, nothing goes to it, so it never go beyond 27.3
          we dont want to go into that coz it is totally another topic
          i dont have anything that is loose, notice how the sound stops immediately after turning off the pc and lcd while still on bulb
          • GraphicMan
            • Aug 2018
            • 124
            • Egypt
            the problem is fixed by replacing a capacitor that was reading less than what it should, thanks for everyone tried to help
              HP EliteBook 1050 G1 + LG SJ2 Bluetooth Sound Bar Notebook 1000 Specification for Upgrade or Repair
              This specification for the HP EliteBook 1050 G1 + LG SJ2 Bluetooth Sound Bar Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + LG SJ2 Bluetooth Sound Bar boardview and 1050 G1 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
              09-06-2024, 02:34 PM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • repair-it
              TOSHIBA DLP 52HM95 How to reset timer module on bulb
              by repair-it
              I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
              Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
              10-11-2023, 07:18 PM
            • ezenia
              LUMIMAN Smart Bulb IC ID?
              by ezenia
              I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
              In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
              04-28-2025, 05:56 PM
