Did I do anything wrong?
  • epixie
    • Jan 2014
    • 11
    So I had this problematic HP Touchsmart 300 "all-in-one" computer sent to me. It would run for a few minutes, and then cut power off. Oddly enough, the LED on the power button would stay lit, but system goes on a complete dead stop. I checked the motherboard and everything (overheating and the like), and it looks fine. So that leaves the power supply...
    Since this unit uses a propietary Delta DPS-200PP-171(a) power supply, it leaves my usable spare ATX power supplies out of the question for troubleshooting.
    Previously, I successfully recapped a Dell E153FPc with some UCC caps salvaged from another board - prior to that, the monitor would stay on for a few minutes and then shut off whilst the power button LED stayed lit. So I guessed it must be the same problem.
    Off to Digikey, I purchased some Nichicon caps:
    RATING QTY L X D NOTES PICK
    16v, 1000uf 3 ea 20X10MM UPW1C102MPD x
    10v, 1000uf 1 ea 20X8MM UPW1A102MPD6 x
    50v, 10uf 2 ea 8X5MM UPW1H100MDD x
    50v, 47uf 1 ea 11x7mm (guess) UPS1H470MED x
    50v, 100uf 1 ea 10x8mm (guess) UPW1H101MPD
    450v, 150uf 1 ea 30x25mm P11804-ND x
    After soldering, I tried to boot up the system, the fans would spin but the LCD will not come on. Also, I checked the red (5v) wires show 0 volts on the multimeter but the 12v rail still has 12v present on it. If someone here has the schematics for the DPS-200PP-171, I'd like to have one; as well as your input.
    When I get back from my regular day job, I'll try to post some pics of this baby.
    Thanks!
    • Jul 2011
    • 6018
    Re: Did I do anything wrong?
    Did you recap the power supply ?
    Also check and make sure that you did not put any cap in backwards
      • Jul 2011
      • 6018
      Thanks!
      Please Do this this will help
      • epixie
        • Jan 2014
        • 11
        I hate proprietary power connectors.
        Ugh.
        • selldoor
          Slow Learner
          • 7870
          Check all your joints with a magnifying glass also as the original problem could have been due to a bad joint check the whole boards. Pic...6007
          a few of the joints dont look great but that may just be the picture.?
          • epixie
            • Jan 2014
            • 11
            RoHS lead-free solder.
            My Pace MBT-200 has had a hard time melting the through-hole joints. I've got it set in the max setting but it wouldn't budge. I've checked the board for any cracks, but I can't really see anything that would indicate otherwise.
              • Jul 2011
              • 6018
              Frist thank you for the photos
              My Pace MBT-200 has had a hard time melting the through-hole joints. I've got it set in the max setting but it wouldn't budge. otherwise.
              Here is a trick you can try put lead based soldier on the joint then suck all of away then reapply the soldier this works for me about 99%of the time
              from the photo the big main board there look to be some ? able joints
              What are the brand names on these caps that are on this board
              • epixie
                • Jan 2014
                • 11
                Done that, including tinning the desoldering tip with 60/40 solder. It sort of worked, but not as fast as running my Hakko 936 at 405*C and a Soldapullt on the hole. Hmm, weird
                The replacement caps are all Nichicon PW series as well as one PS cap (UPS1H470MED). I wonder if my selection of replacement caps has something to do with it.
                • SeanB
                  • Jun 2013
                  • 41
                  • South Africa
                  Tried reflowing those diodes on the secondary side. Some look like they are suspect, which would cause a dropped supply rail. Also on the control board some of the through hole parts at the bottom by the connector look dry jointed.
                  • epixie
                    • Jan 2014
                    • 11
                    EDIT: Got it to work...sort of. Let's see what'll happen in the next 24 hours.
                    EDIT: Worked, but still shuts off at random intervals. Hmmmm....
                      • Jul 2011
                      • 6018
                      I would add this as well any joint look like it has a lot of flux I would redo those joint as well
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Hint Hint... I've had success with adding extra flux, that tends to help those stupid lead-free joints melt.
                        Do you know exactly what happens when it shuts off? Like, do the main rails go down, or does the standby go down too?
                        I'm thinking it is probably a bad solder joint. Or something could be wrong with the motherboard.
                        Muh-soggy-knee
                        • epixie
                          • Jan 2014
                          • 11
                          It goes into an unrecoverable 'standby' mode where the power button LED is still lit, but everything else is powered down. So it means the mainboard is still powered, but it has entered a powered-down state that it couldn't get out. Holding the power button long enough won't turn the unit off, I have to physically unplug it. I've seen it happen in the Dell monitor I recapped several months ago -- semi-bulged CapXon caps.
                          I've checked the HP motherboard and everything looks like fine (physically) for now, as I do not have access to an ESR meter. The HP motherboard has brown United Chemicon caps on it, I think. The rest are surface mount radial caps.
                          Now here's the weirder twist of things: I've consistently powered up and down the unit, and every time it would go off, the amount of time it would stay 'turned on' when I re-powered it, would be decreased.
                          Other than that, I catched an Ltec(!) cap covered in heat-shrink tubing while I was desoldering the SMPS daughterboard off - the one that has the Fairchild KA7500c chip on it.
                          More later. Insights welcomed.
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            replace it. i have had a Macintosh plus refuse to shut down because of a dry cap on the daughter board for the PSU.
                            Follow the white rabbit.
                            • epixie
                              • Jan 2014
                              • 11
                              The Ltec cap?
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                The Ltec cap?
                                yer. 25uF 50v, it was at 5uF
                                • epixie
                                  • Jan 2014
                                  • 11
                                  UPDATE: Now waiting for the shipment from Mouser. We'll see what'll happen next.
                                  Part number is UPS1H220MDD.
                                  • Khron
                                    • Sep 2006
                                    • 1350
                                    • Finland
                                    What series are the Chemicon caps on the motherboard?
                                    I've read around here that KZG/KZJ don't really like heat, and are prone to failure without bulging / venting / leaking.
                                    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                                    • epixie
                                      • Jan 2014
                                      • 11
                                      I'm busy with other things right now, and short of money
                                      The mainboard has two large radial KZG caps and some smaller Lelons (the small 5x8mm ones, I think). Once I have an ESR meter, I'll try to take a look on them.
                                      • epixie
                                        • Jan 2014
                                        • 11
                                        UPDATE:
                                        Replaced ALL electrolytic caps on the power supply with Nichicon PS and PW caps; still has the random shutdown. Fires right up, boots all the way to Windows...and suddenly cuts off. Oddly enough, the WLAN module still keeps on blinking.
                                        Odd, very odd.
                                        Can someone give their insights?
                                        • Jeff'sTech
                                          Dell Latitude 7420 BIOS Unlock Gone Wrong
                                          by Jeff'sTech
                                          Hello everyone.
                                          I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                          11-08-2023, 03:30 PM
                                        • Vincent Kahle
                                          Winbond 25Q16JWNIG – Asus ROG Strix Scar 18 G814JZ bricked after wrong flash – Need help
                                          by Vincent Kahle
                                          I hope someone can help me.
                                          I have an Asus ROG Strix Scar 18 (G814JZ) laptop with a Winbond 25Q16JWNIG chip on the motherboard.
                                          Unfortunately, I flashed the wrong file (BIOS/EC/other region – I'm honestly not sure anymore), and now the laptop is completely dead: no display, no fan spin, no reaction at all.
                                          I have a CH341A programmer and I'm able to read and write to the chip. However, I'm not sure which software is best (AsProgrammer, NeoProgrammer, etc.) or if there's anything specific I should watch out for.
                                          A valid BIOS/EC backup...
                                          06-05-2025, 09:27 PM
                                        • Andreasbest
                                          HP 840 G1 Completely wrong system info
                                          by Andreasbest
                                          Hello.
                                          I received a 840 G1 with completely wrong system info in BIOS.
                                          Serial Number and everything is wrong, even the Model is wrong (written as 850 G1)
                                          How can i reset these info?
                                          Thank you!
                                          03-22-2022, 03:59 AM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
                                        • alegatorul
                                          Cello Tv . wifi 40" board HK.T.RT2841P638 wrong file update
                                          by alegatorul
                                          hi,
                                          i've being using this Cello tv, uk brand, C40rts, HK.T.RT2841P638 main board, for a year or more.
                                          Last week i've found an update, 3rd party, that i though it was close to my board. Inserted on a usb stick the install.img, started the Firmware update, ended, rebooted and nothing. The led (red-green) keeps flashing, backlight is on but to response on remote.
                                          I've retried with original fw, no success. Hooked the uart Cp2102, putty, tried to swuu command (to update from usb), it goes for a while the get "cpu reset" on laptop screen that brakes the process and halt....
                                          11-03-2024, 02:28 AM
