Need Help indentifiying this autotransformer
  • Bubbsy 2002
    • Nov 2010
    • 56
    Hi all, need help identifying this auto-transformer manufacturer.
    It belongs in a Venmar EVO5 700 Hepa HRV, that was toasted by 180v power surge (Newfoundland Power).
    I have been able to repair other items that were destroyed i.e. my doorbell with doorbell transformer, my Husky Central Vacuum (used a doorbell transformer to fix too).
    So I am just assuming this is the case with this as the board looks perfect and fuse on it was not blown, but no power.
    Any help in this regards would be greatly appreciated.
    Thanks,
    • 31022
    HELMS-MAN INDUSTRIAL CO LTD
    • Bubbsy 2002
      Bubbsy 2002 commented
      Editing a comment
      Thanks for that, take care. Would happen to know where I can find the part, I just looked at Digikey they don't have this company name?
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    Yes their sign is right on the transformer
    • Bubbsy 2002
      Editing a comment
      I knew that, thank you.
  • CapLeaker
    Leaking Member
    • 8158
    Whats wrong with it? Primary voltage going in and nothing coming out the secondary? Check the thermal fuse inside or replace the transformer with something else.
    • Bubbsy 2002
      Editing a comment
      Yes, I had no power to control board (board has fuse not blown, parts look good), so I am suspecting autotransformer is the problem. I am attaching a picture of transformer with shell off (wondering where fuse my be lurking).
  • Bubbsy 2002
    • Nov 2010
    • 56
    Here is picture of opened transformer.
    • CapLeaker
      Leaking Member
      • 8158
      I'd say the thermal fuse blew inside of the transformer. You'd have to unwrap the blue tape and dig around on the primary winding.
      • Bubbsy 2002
        Editing a comment
        CapLeaker, thank you for that. I watched a few Indians on Youtube unwrapping transformers and this one is complex compared to what I watched.
    • Bubbsy 2002
      • Nov 2010
      • 56
      Finally found that fuse, thanks all. Took me an hour to dismantle and unwind hopefully I can reuse the wire.
      • Bubbsy 2002
        • Nov 2010
        • 56
        Thanks to all who helped me out with this particular problem. Another item has been save from the landfill. I finally got a fuse and rewound and re-wrapped the auto-transformer.
        • ohren
          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
          by ohren
          Hello!
          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
          Measured voltages with no load:
          After rectifier diodes
          12V: 6.17 V
          5V: 5.67 V
          Secondary transformer pins AC measurement (really don't know if this says anything)
          12V: 2-2.5 V
          5V: 1.04 V
          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
          03-18-2023, 10:33 AM
        • mikey5791
          Is it possible for transformer substitution?
          by mikey5791
          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
          My questions are
          1. How do i test to see if the transformer is in good working condition?
          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
          Hope you guys understand what i was asking. My intention is...
          11-03-2022, 02:11 AM
        • dennis_elx33
          3PHASE STEP-DOWN Transformer in Check
          by dennis_elx33
          Hello All,
          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
          Problem statement: Power tripped Off
          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
          Action Done:
          1) Replaced the faulty parts with good spare.
          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
          12-02-2024, 06:52 AM
          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 04:40 PM
          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 12:00 PM
