Acbel Power Supply Tester
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    It seems a nice tooling for computer PSU, i am planning to order one.
    It semms made in Taiwan, not mainland China.
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: Acbel Power Supply Tester
    Very cute. I'm guessing M1 is a reference IC. The other four look to be LM339 quad comparators. Probably the sections are paired to form a window detector for each voltage (12 sections, six pairs, six voltages monitored) so that it detects both out-of-spec low and out-of-spec high conditions.
    PeteS in CA
    • gonzo0815
      • Feb 2006
      • 1600
      You only have to add a seriouse load to it and you have a realy good unit.
        by sam_sam_sam
        03-31-2024, 02:12 PM
        Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
        by sam_sam_sam
        I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
        One other check that...
        08-03-2021, 06:41 PM
        by sam_sam_sam
        07-01-2024, 06:34 AM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
