Yamaha RX-V765 blowing mains fuse
    Got another amp to repair... this beautiful Yamaha 7.1ch HDMI amp is eating mains fuses for breakfast. Cost approx £27 including delivery, cheaper than my old RX-V465DAB!
    Will turn on & work briefly (VFD lights up and shows "Main Zone"), but no audio, buzzing from transformer and pop goes the fuse!
    Checked the outputs of the transformer and can't find any -obvious- shorts. I hook lightbulb in place of fuse & put the scope across the output of one of the taps and I can see the positive section of the wave is very stunted... the negative section looks OK. Amp just clicks on and off rapidly with lightbulb due to reduced power.
    I suspect though have not yet confirmed that the bridge rectifier has one or two failed diodes internally. All O/P transistors tested OK, but since the short shows on the transformer as being asymmetric I believe that it is probably a short that is hiding behind a diode (shorted output stage would lead to both halves of wave being equally stunted.)
    I'm going to try with my variac later.
    Re: Yamaha RX-V765 blowing mains fuse
    Oops -- please will a moderator move this to the audio equipment forum.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Hm, does this unit have some sort of inrush protection? That is one way to kill rectifier diodes... xD
      But, yeah, sounds like there is a problem with the bridge rectifier.
      Hey, got any pics? BTW, what capacitors are in this unit?
      Muh-soggy-knee
      • stav242
        Samsung BN44-006056A Blowing Mains plug fuse.
        by stav242
        ive picked up a Samsung UE32F5500AK TV with a BN44-006056A power pcb.
        It was reported as `blowing the fuse` - the 3A one in the plug.
        on quick inspection of the power pcb, a ceramic capacitor CM802 has blown apart.. photo attached.
        Ive found a PDF of the circuit schematic and can identify the neighbouring components (RM801, RM802) but cannot find CM802 on the schematic.
        Can anyone identify what CM802 is ?
        thanks.
        S....
        12-30-2021, 10:45 AM
      • Tips
        Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
        by Tips
        Looking for some assistance please.
        Trying to repair a PD27AOQ samsung power board.
        Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
        Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
        Testing it the fuse blows immediately power is turned on.
        diodes dm852 and dm853 test as shorted when in the board but fine when removed.
        any assistance, guidance would be appreciated.
        04-11-2024, 11:24 AM
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
      • Bootleg1
        Samsung UN65KS9800FXZA T-con fuse blowing
        by Bootleg1
        Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for...
        02-04-2020, 01:05 AM
      • jshhh
        Help replacing fuse on my Mimaki CJV300-160 vinyl printer
        by jshhh
        Hi guys,
        I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
        How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
        Anybody know how to remove this type of fuse?
        (The fuse is toward the bottom of the image labeled F2)...
        06-17-2025, 01:35 AM
