My power supply has all the standby voltages and pw_on but no 12V. I disconnected all other boards and jumped the psu still no 12V. Anyone know what could be bad on here? Caps checked good except I didn't test the tiny ones. Maybe regulators bad?? I put my dmm on diode mode and checked them I got a reading in both directions and no reading in both directions. I'm guessing I have to pull them out of circuit to test. The person I bought it off said the repair shop said it had a bad fuse. The only fuses I see are the main which is obviously good and another one by the pin connector which tested good for continuity.
No 12 volt putput DPS-172EP-1A
Tags: None
Re: No 12 volt putput DPS-172EP-1A
Pics?Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more! -
You may want to post this in TV forum:
http://www.shopjimmy.com/vizio-0500-...upply-unit.htmNever stop learning
by sam_sam_samHere is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...-
by irepair559PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...01-05-2023, 12:32 AM
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by YanlebHi, I just want to share the repair of my Samsung HPT5054X-XAC plasma TV with no picture. It will end up repairing the BN96-04881A (LJ92-01452A) main logic control board. I hope it will help someone out there.
The TV sound was working perfectly, but no picture at all. I've checked the various voltages on the power supply and found no VS voltage. After some investigation I found that VS_ON was not present.
I traced down the source of the VS_ON signal to the main logic control board.
Voltage at C2014 was good at 5.3 volt and coming from the power supply...05-06-2021, 11:08 PM - Loading...
