Chaging PC POWER SUPPLY SUPERVISOR output voltage
    • Jul 2011
    • 6070
    I have a computer power supply I want to change the output voltage from 12 volts to 14 volts What would I need to change in order for this to work
    It use this chip
    Weltrend WT7527
    PC POWER SUPPLY SUPERVISOR CHIP
    I will post a photo of the board later today
    But it look very much like the board in this post
    https://www.badcaps.net/forum/showthread.php?t=32032
  • Escort Eagle
    • Jul 2012
    • 110
    Re: Chaging PC POWER SUPPLY SUPERVISOR output voltage
    You need to change the Main Transformer or you have to rewind it and add few turns to get 14V .
      In most cases, locating the feedback circuit and increasing the top resistor in the pair, or bottom resistor, will increase the output voltage. You typically can get an additional 30% to 100%.
        • Jul 2011
        • 6070
        I want to thank both of you for the info
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          The way tom suggested is the best way to change the voltage, however there are limits. Eventually, you will need to change the windings on the transformer to get a higher or lower voltage, BUT, only a 2v difference should not cause that much trouble.
          I suggest changing the lower resistor in the feedback voltage divider.
          Muh-soggy-knee
          • domas
            News Hater
            • May 2013
            • 323
            • Denmark
            http://boginjr.com/electronics/lv/atx-mod/
            3 components to do that, use this mod myself, good luck
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • labello
              Power supply Termaltake Smart Se 630w any voltage in output
              by labello
              Hello everybody I try to fix thi power supply, I have voltage in bridge rectifier, and also in the large capacitor , so I thought the problem was in the pfc but then I found all mosfet ok(tested out of the circuit so I just moved on in the low voltage and here I found a short of one of the diode rectifier. I'll replaced it already but it's completely dead, I mean any stanby voltage and the other voltage is not present. I don't have oscilloscope to understand if the chip work how can I test it? Thank you for the help 🙏
              09-09-2023, 12:06 PM
            • dicky96
              L4973V5.1 Power supply giving too much output voltage
              by dicky96
              Hi guys
              This power supply is from an FM Radio transmitter
              It takes an input of 28V and should output some lower voltage. When I first looked at it I found that there is a zener diode D3 directly across the V out to ground and it was short circuit.
              I removed the Zener, there are no markings to determine it's correct value, and I don't know what Wattage it should be either, plus it broke in half. I took a photo comparing it to a 1N914 signal diode and a smaller zener which I have (which I think are 0.5W but I am not sure) and also a resistor so maybe someone can...
              01-15-2021, 06:29 AM
            • AhhAhhAhh
              Game Gear Power Supply 2110K No Output Voltage for 1 pin
              by AhhAhhAhh
              I'm working on reviving a Game Gear Power Supply that has some issues with the voltage output for one of the pins. The power supply should provide the correct voltages for each pin (please see attached photo) and I could not get 34V for the last pin. In fact, I got like 0.4 to 0 volts when measured with a multimeter when it powers on.
              What I did so far was to change the 3 electrolytic capacitors and have also tested using an ESR meter and all 3 capacitors are fine. Next I checkED for any shorts and I discovered that both solder joints (+) and (-) for one capacitor...
              10-19-2021, 02:54 AM
              LM358 LM358S-13 Datasheet
              The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
              Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
              10-07-2024, 04:12 AM
