Above power supply is from Teco tv but is also used in Viewsonic models. No standby light on tv. Checked caps in psu replaced many of them on secondary side as they had badly swollen both above and below. Fuse F1 T4.OA had not blown so thought it was only cap issue but still no standby light when retested.
Have now fitted the full power supply repair kit even though fuse F1 had not blown thinking that that should resolve the problem but still fails to work with still no standby voltage on testing back in tv. Has anyone any knowledge of this power supply with any ideas as which component is likely to be the cause of this fault probably caused by bad failing caps in power supply that didnt cause main fuse to blow? Be very grateful for any help.
