Re: Seasonic SS-500GB "ticking"
I reflowed a few solder joints that looked iffy, and the ticking has stopped.
Rather than risk the motherboard again I just put 2 old DVD-RW drives on the supply for a light load. The voltages look OK on my DMM (best one I have here today is a Fluke 117). And checking for ripple with the meter set to AC volts gives about 25 mV. But the scope shows horrible noise bursts about every 13 uS (76.9 kHz) of almost 10V peak to peak but very short duration. A pretty good supply set up with the same load shows less than 90 mV peak to peak. Note to self: you can't check SMPS ripple with a Fluke 117 [edit: I just checked the Fluke site and AC V & mV accuracy is only specified to 1 kHz].
So is that most likely just output filtering on the SS-500GB? I will try to check all the caps, as usual...
Does the supply function as it is supposed? All voltages, ripple (if you have hardware to measure it).
I had a similar issue while i was working on my q-tec adjustable PS (it was outside the case of course). I was ticking at low voltages and buzzing from voltages 10++ at voltages over 12V it was squeaking like crazy and would shut down. I even managed to burn some components like that.
Problem solved by putting it back to the case (grounding). Please check your y-caps.
You can touch GND with your finger while its making sound, if it silences itself then it probably is grounding issue.Leave a comment:
BD001 (bridge rectifier) checks out OK.Last edited by Uniballer; 09-17-2013, 01:41 PM.Leave a comment:
D301 (axial) and D304 (TO220 on the heatsink) both appear good with a DMM diode check.Last edited by Uniballer; 09-17-2013, 12:15 PM.Leave a comment:
Last night I noticed this SS-500GB started making a ticking sound. I made sure it wasn't the fan, then opened it up. I put a tube to my ear (aka redneck stethescope) and the sound appears to be coming from near the toroid by the primary cap. The caps all look OK to the eye. The primary is a Rubycon CE 330uF 450V. Most everything else is United Chemicon KZE series.
The more load is on the power supply the faster the ticking. When I start the power supply with no load it ticks maybe two or three times per second, but it ticks much faster when the entire system is running.
Any clues? Schematics? Advice? Thanks.Leave a comment:
Any clues? Schematics? Advice? Thanks.Tags: None
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by JohoHi there, I've got a HP Prodesk 600 G2 Mini on my bench, that turns on but no picture.
Model: HP ProDesk 600 G2 Desktop Mini
Product No: Y3J22EC#ABD
BID=15WWP3ET6**#SABD#DABD
Serial: CZC632BBCJ
First I thought maybe BIOS got corrupted. Someone sent my corrected BIOS that I flashed. Now symptoms are: Mini starts when power is plugged in, Fan turns on and gets faster and faster until it's at 100%. Nothing gets excessibly hot.
When I desolder the BIOS chip I get Beep codes / LED codes "BIOS is missing"
Without CPU I get "CPU...03-07-2025, 09:18 AM -
by sew333Hello.
My previous pc ,i bought in 1 january 2019,here are parts.
9900K
Asus Prime Z390-A
2x16 GSKILL
Corsair 750RmX
2080 Ti Waterforce
monitor Acer Predator
There was not issues in house with tripping breaker/s.
In november 2019 i bought only new monitor Aorus AD27QD and new psu Seasonic 850W Ultra Platinum.
So in november 2019 i bought new monitor Aorus AD27QD and new psu Seasonic 850W Ultra Platinum. After 3,5 months , in february 2020 ,something tripped breaker in night and that... -
by SolvikHello
i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
All voltages are normal.... -
by mikey5791Hi to all forum members,
This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
Fyi, i desoldered the secondary side electrolytic cap those over 1000uf... - Loading...
