Switching the guts of 2 psus?
  • tysercom
    • Jan 2007
    • 5
    hello everyone!
    i have an asus barebone that has a custom-sized psu, would it be possible to swap everything from a smaller matx sized psu. I need extra power in the barebone.
    any feedback would be great. thanks in advance!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Switching the guts of 2 psus?
    If it fits sure no problem ;-)
    might be some useful info here...
    https://www.badcaps.net/forum/showth...light=seasonic
    • tysercom
      • Jan 2007
      • 5
      that looks like plenty of of wire to desolder, what a pain. is there anything quicker or easier. not that i am lazy, just don't have much time.
      • starfury1
        • May 2006
        • 1256
        well not sure on the bare bones case psu
        but if its follows standards atx wire pin out/ connectors you shouldn't have to de-solder any of of the secondary DC supply wires.
        (think they do)
        If thats what you are referring to.
        just a matter of de-gutting the bare bone and putting the other in.
        provided it fits with no problem...
        Stand offs for the pcb's are usually pressed out of the case. so these must match up or you will have to modify...i dont know the specs of the bare bone psu
        So Just be careful that the pcb does not short to the BB psu case anywhere or you may well end up with sparks flying and a dead psu
        Also make sure of what needs to be earthed is.
        You may need to rework the mains side and yeah you could possibly be breaching some safety standard somewhere...
        simple answer would be to get a bigger psu that fits but I am guessing
        1 you can't
        2 expensive... cause its in a custom size case
        3 you got and mATX that is bigger and want to save money...
        Post a few pics of both psu open if you can
        lastly heat may be an issue if what you got isn't big enough
        but someone else may know if if its easy to do or not.....or what issues you will have to overcome
        Just my thoughts on it HTH
        cheers
        • tysercom
          • Jan 2007
          • 5
          1 you can't
          I can't buy this type of custom sized psu, or else I wouldn't of asked.
          Well, I 'm now thinking of just pulling everything out of the custom psu and using it as support for an m-atx psu. Would it be better? Or could i just modify the case so it would accept a m-atx psu?
          Edit: The psu is a delta electronics custom psu that measures roughly 120mm*80mm*80mm
          • bgavin
            • Jan 2007
            • 1355
            Throw away the case and use a standard case and PSU.
            I come across this situation all too often with my clients. In fact, I have two machines in my office like this, as of this writing. They both use a non-standard PSU with the fan housing protruding out the rear of the machine. The fan is the problem with both PSU, but I can't find a source for thin fans. So... the PSU is useless, and the case also.
            Time is money. It is cheaper for my client to have me replace the case/psu than to spend endless hours trying to keep their non-standard gear alive.
            • tysercom
              • Jan 2007
              • 5
              hmm, if i throw away the case and psu, i might as well buy a new pc.
              I am planning to use this barebone for a htpc and some occasional gaming. So buying a new case annd psu is not a option here.
              • tysercom
                • Jan 2007
                • 5
                oopps, the psu size should be 120mm(length&height), 80mm(width).
                The p/n is dps-250ab-7.
                  03-31-2024, 02:12 PM
                  07-01-2024, 06:34 AM
                  After all of...
                  07-13-2024, 08:14 PM
                  DVR camera recorder switching power supply capacitor failure really
                  These cheap non brand capacitors at it again
                  Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                  Well at least I have the cameras back on line I to try the...
                  01-22-2022, 06:28 PM
                  Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
                  I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
                  One other check that...
                  08-03-2021, 06:41 PM
