Nokia ACH-6E, AC-4E
  • neuron
    • Feb 2013
    • 126
    • Portugal
    Nokia ACH-6E, AC-4E
    I have several Nokia charger - ACH-6E, AC-4E ...
    All of them have a 10 Ohm resistor in the 220 V.
    220V -> 10 Ohm -> 4 diodes -> 2x 6,8 uF 400 V ...
    and in AC-4E the resistor is burn.
    Tested the Caps with EVB - ESR ok
    SMD with Smart Tweezers ok ... several caps and resis.
    Why 10 Ohm blow ?
    Best Regards,
    Ruy
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Nokia ACH-6E, AC-4E
    Shorted out diodes, or power transistor.
    The 10 ohm resistor is used as a half-assed replacement for a regular fuse, because it is cheaper
    Can you get some good pictures?
    Muh-soggy-knee
    • cheapie
      null
      • Jul 2010
      • 849
      I had a charger once where I had replaced the primary cap. I didn't notice it at the time, but I had a solder bridge across it. I plugged it in and the resistor burnt up. Thinking it wasn't important, I jumpered it and plugged the charger in again. The bridge rectifier promptly exploded and tripped the breaker as well.
      • neuron
        • Feb 2013
        • 126
        • Portugal
        Thank you ben7 and cheapie,
        I have LCR and ohmmeter - "Smart Tweezers".
        I will check and report - the 4 diodes or the T.
        The L10 is very low and the reading is very nH ... its strange
        Best regards,
        Ruy
        • neuron
          • Feb 2013
          • 126
          • Portugal
          The quality is bad ... Hope you can id.
          Best regards,
          Ruy
          • neuron
            • Feb 2013
            • 126
            • Portugal
            Transistor (in circuit)
            Z= 114 Ohm, 4.941 Ohm, 116 Ohm
            4 Diodes
            Z= 928.9 Ohm, 926 Ohm
            Different model and (its working) the Transitor Z=172 KOhm between legs.
            If I put in AUTO MODE the "Smart Tweezers"
            Transistor - in good unit - 929 pF or 12 uF
            In bad unit always Z=116 Ohm and 4,941 Ohm
            Regards,
            Ruy
            • mariushm
              • May 2011
              • 3799
              Pictures are useless. Move the camera further away and try to snap pictures again. Get the pictures in focus, it's not rocket science.
              • neuron
                • Feb 2013
                • 126
                • Portugal
                The two big caps in left 6,8 uF 400 V.
                4 diodes 1N4007
                The green Resistor 10 Ohm - burn.
                The Inductance L10 between the 2 big caps and the 4 diodes
                I can't measure the Henry ..... very low mOhm
                And 2 SMD - R21, R14 usually are black with the Ohm numbers, this ones are green ...
                Regards,
                Ruy
                • neuron
                  • Feb 2013
                  • 126
                  • Portugal
                  Any member see leaky capacitor in this 6,8 uF or in final stage ?
                  In the 220V the caps get short?
                  But with LCR everything ok. 0,2 - 0,5 - 1 V
                  Regards,
                  Ruy
                  • imp
                    • Aug 2010
                    • 125
                    • Sweden
                    Again, please provide us with focused pictures. These are useless for us
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8711
                      I don't know if this is any use but here's my Nokia AC-10C guts:
                      Fairly common 2-transistor optoisolated feedback design with fullwave rectifier. This one works actually, but the problem I had with it turned out to be mechanical...
                      • neuron
                        • Feb 2013
                        • 126
                        • Portugal
                        Thank for your comments,
                        But at moment I don't have a camera with better resol.
                        I described the components in detail, If you have any doubt about any piece please tell me.
                        Any comment:
                        "Any member see leaky capacitor in this 6,8 uF or in final stage ?"
                        Sometimes they leak - shortcircuit in 220V, ... antique radios
                        Regards
                        Ruy
                        • imp
                          • Aug 2010
                          • 125
                          • Sweden
                          I can´t see any faults in the pictures you provided - they are to blurry.
                          You must understand that it´s impossible for us to help you (or any other member) without proper information and, in most cases, clear pictures. Otherwise it´s like telling a blind person how the color red looks like ....
                          • neuron
                            • Feb 2013
                            • 126
                            • Portugal
                            And the values for the short - Ohm? .... I write the values i have in circuit ... strange or normal????
                            Any member have experience one this with modern circuits?
                            Regards
                            Ruy
                            • neuron
                              • Feb 2013
                              • 126
                              • Portugal
                              Thank you for your comments,
                              Update
                              I removed the coil (between 2x 6,8 uF 400 V).
                              And the short-circuit disappear (test with a series light bulb).
                              The diodes and the first 6,8 uF-400 V ok - the first cap has hundred volts
                              Insert again the coil and removed the second 6,8 uF 400 V ... short on.
                              The 2 caps and the diodes are ok.
                              The board has TH 2267.1 0706.
                              I searched and this is a special IC.
                              Regards,
                              Ruy
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Update
                                Regards,
                                Ruy
                                Replace the main switching transistor
                                Muh-soggy-knee
                                • neuron
                                  • Feb 2013
                                  • 126
                                  • Portugal
                                  Removed the transistor and
                                  |_1_2_3_|
                                  Pins 1 - 2 -> 4,6 Ohm in all directions.
                                  The T. has a short.
                                  "Petit Problem" the bottom is all burn and I can't get the name and the number.
                                  Measured the main path in caps, in main transf. and now
                                  we don't get low Ohm.
                                  Connected 220V and "no short".
                                  The only problem, I can't read or get the type of Transistor.
                                  Best Regards,
                                  Ruy
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    |_1_2_3_|
                                    The T. has a short.
                                    Best Regards,
                                    Ruy
                                    Which pin on the transistor connects to the "-" of the 400V filter capacitors, and which pin on the transistor connects to a pin on the transformer?
                                    Muh-soggy-knee
                                    • neuron
                                      • Feb 2013
                                      • 126
                                      • Portugal
                                      Pin 1 -> TH 2267.1 0706 right pin (bottom),
                                      Pin 2 -> The transformer,
                                      Pin 1 -> "-" Caps but there is a serie of SMD
                                      Regards,
                                      Ruy
                                      • neuron
                                        • Feb 2013
                                        • 126
                                        • Portugal
                                        As I mentioned before I can send details of components.
                                        Regards,
                                        Ruy
                                        • Dvsr
                                          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                          by Dvsr
                                          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                          After replacing the caps I started testing out the speaker. It seemed...
                                          09-10-2025, 10:20 AM
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                        • corrize
                                          Replacing resistor fuse in Sony DV charger
                                          by corrize
                                          Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                                          So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                                          It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                                          06-30-2025, 06:59 PM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
