Odd Thermaltake TR2 550 problem
  • Rusty!
    Learn by doing
    • 18
    • United Kingdom
    Well it's is to me, at least.
    The aforementioned PSU powers my PC like a champ, however, it can't stop powering it! Tell the PC to shutdown, and it only half does... fans still spin, power LED remains lit. The LED on the PSU turns orange to indicate that it "thinks" it's properly shut down, and the EON Powerdown it's plugged into kills the monitor and speakers, so it has dropped its power consumption significantly.
    The PSU fires up (well, not exactly, but can't think how else to describe it) with no motherboard connected, multimeter shows both 5v and 12v rails are live (tested at a molex plug).
    Popped it open and found the entire cold side (almost) is under a huge heatsink, which was annoying. The only visible cap outside it was swollen so replaced it, but it didn't change anything.
    Any ideas what I should be looking at here? Have attached a picture of the offending thing, but I figure it's not much use due to the heatsinks.
    Cheers!
  • c_hegge
    • Sep 2009
    • 5219
    Re: Odd Thermaltake TR2 550 problem
    Have you tried a different PSU? Could the problem be with the motherboard?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      It indeed is strange if it will come on when the ATX plug is not connected. Usually there's either a pull up resistor on the input to a transistor on the green wire (!PS_ON) - so if the ATX is disconnected but AC is plugged in, VSB will make that wire close to 5V. Is this the case or is it down near grounded now?
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Originally posted by Rusty!
        The PSU fires up with no motherboard connected,
        I'm fairly certain that is not a motherboard problem.
        • c_hegge
          • Sep 2009
          • 5219
          Ah, whoops. missed that bit.
          • Rusty!
            Learn by doing
            • 18
            • United Kingdom
            Yeah, with another PSU (and a few adaptors) everything behaves as normal.
            Green wire is showing 2.41v in this weird "off but still kinda running" state, measured between it and either of the adjacent ground pins.
            • Rusty!
              Learn by doing
              • 18
              • United Kingdom
              Checked PWR_OK signal, it's 0.10v when in "standby" and 4.92v when fully on. Looked up the ATX spec and that seems to be within the thresholds they should be, so at least this thing is doing something right.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8716
                "!PS_ON" - yes this is an _input_ but you should still see a voltage on it (make sure you're using a 10M or better impedance voltmeter, the 1M cheapos may affect the results)... PWR_OK is an output of the PSU and motherboards would not boot without this signal working properly.
                What happens if you hook up the +5VSB wire (purple) to the green wire? (may want to use a resistor from 470 ohms to 1K ohm or so) but don't think it should hurt anything)? Will it shut off? If this is the case then somehow that internal pull-up resistor blew...
                If it dows not turn off, then the power on circuit is really broked and will need investigation (circuit extract/schematic) to figure out...
                • Rusty!
                  Learn by doing
                  • 18
                  • United Kingdom
                  PS_ON is showing 2.41v with ATX disconnected.
                  I don't have a resistor handy, but tried purple to green with a handy bit of wire, nothing happened. Will see if I can rob a resistor out of something and try that next.
                  • PeteS in CA
                    • Aug 2005
                    • 3586
                    • USA, Unsure of Planet
                    2.41V is probably in the uncertain state range for TTL, if that's relevant. But is that 2.41V measured with a DMM? If so an oscilloscope might show that 2.41V to be an average voltage of a line that is actually hashing between high and low (in which case PS_ON is getting repeated "On" commands). I don't recall whether the "On" command is a low or a high, but it sounds like the pull-up or pull-down resistor on that input may be open (or a bad solder joint causing it to be open).
                    PeteS in CA
                    • Rusty!
                      Learn by doing
                      • 18
                      • United Kingdom
                      Yeah just a DMM, no scope here.
                      I can't see any bad joints, although some of them look more like MIG weld blobs where multiple wires are being joined.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8716
                        If it's in that funky state and you connect the green to the purple wire, then we know that the first stage is probably messed up and not just a pullup problem. Probably need to do a full circuit extract here, perhaps that input transistor is bad, no idea...
                        I don't think that first stage has any oscillator on it... For a working PSU the input should be held high due to the pullup and the motherboard will pull that wire green wire low (just like the "short" trick). One ATX PSU I saw this was fed into an NPN transistor whose collector is pulled low when the ATX connector isn't plugged in or the MB doesn't pull low. With this output low, it's fed into a PNP transistor that will pull its collector high, and this high signal is fed into one of the PWM's voltage inputs - voltage input is too "high" which causes the PWM to shutdown and result in no voltage output, hence "off".
                        ...but this is just one implementation of PS_ON.
                        • Rusty!
                          Learn by doing
                          • 18
                          • United Kingdom
                          So in short, sling it out?
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            It's a nice PSU, so I'd say no. Just needs a bit more dedication to troubleshoot/repair it, though.
                            • kaboom
                              "Oh, Grouchy!"
                              • Jan 2011
                              • 2507
                              Hi there.
                              What do you get when you measure from purple to black/GND?
                              If 5VSB is low, and also used to derive pull up voltage for PS-ON, it's being low will trigger the opamp/comparator that ultimately controls the main PWM. This is because that opamp is usually powered from the standby AUX supply (10-18V).
                              Bad 5VSB caps?
                              "pokemon go... to hell!"
                              EOL it...
                              All style and no substance.
                              guilty,guilty,guilty,guilty!
                              guilty of being cheap-made!
                              • Rusty!
                                Learn by doing
                                • 18
                                • United Kingdom
                                Unfortunately bin day came and I figured I was never going to manage it, and let it go. Looking at it, pretty much everything is either under a large heatsink of surface mounted on a small daughterboard, I think me with a multimeter was never going to manage it once we'd got the basics outta the way
                                • theone111
                                  by theone111
                                  3. Problem: TV shuts down
                                  07-22-2024, 10:36 AM
                                • sonicunderground
                                  Need Help Thermaltake Litepower 500W Problem
                                  by sonicunderground
                                  PSU: Thermaltake Litepower 500W Model: LT-500AL2NC
                                  PCB: G08-CGPA462-PA00 Rev:A
                                  I have this PSU installed in my PC for several years.
                                  The problem is one day my PC cannot detect an external HDD so i think maybe the PSU caps already bad.
                                  So i decided to open the case and found some of the secondary caps already bulging.
                                  Then i recapping all the caps except the primary one (because i tested it with an esr meter and its still good) and i already tested all the new caps too before i soldered them.
                                  After that the psu is good and my pc can...
                                  08-11-2020, 04:59 PM
                                • Zeonalbasta
                                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                  by Zeonalbasta
                                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                  09-13-2024, 01:17 PM
                                • Gibon378
                                  Problem with stopping audio and video for no reason
                                  by Gibon378
                                  PC Specs:
                                  • CPU: Ryzen 5 1600
                                  • GPU: GTX 1080 Palit JetStream
                                  • MOBO: ASRock ab350 PRO4
                                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                  • PSU: XFX 650W (don't remember what model)
                                  • OS SSD: ADATA SP920
                                  • OS: Windows 10 21H2
                                  Problem description:
                                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                  11-19-2022, 09:41 AM
                                • perzyk23
                                  Lenovo T580 - LCD Panel problem - error 0288
                                  by perzyk23
                                  Good morning,
                                  I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                  10-25-2024, 12:42 AM
