Arrows-triangles on PCB
  • onpiopah
    • Apr 2013
    • 22
    • United Kingdom
    Can could someone tell me what these arrows/black triangles mean when they point to a contact. They are on the foil side of a PCb powerboard. I have included a photo with a few on.
    many thanks
    Ian.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Arrows-triangles on PCB
    Is there a coil/choke/inductor on the other side of the PCB? If so, this probably just shows how it's supposed to be connected on the board.
    • cheapie
      null
      • Jul 2010
      • 849
      It might be. The tan material might be an antifuse for it.
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • flibidy
        Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
        by flibidy
        I have here a Magnum IA.100 which belongs to my parents.
        The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
        Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
        What Ive done........
        01-01-2025, 01:26 PM
      • bouny56
        Lenovo E15 Nm-c421 usb-c work only in one side
        by bouny56
        ​Hello
        Laptop E15 I5 10gen
        Mb nm-c421
        I have a problem with the usb-c power dc.
        The motherboard start only in one side of the usb-c
        Replace the usb-c port 2 times same problem
        With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
        Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
        Can the pd controler be the fault ? Or something else maybe ?
        Thx
        02-11-2025, 03:15 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Stephen
        A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
        by Stephen
        Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
        05-29-2025, 10:35 AM
