Haier Thermoelectric Cooler - Power Supply Output Anomaly
  • bobbyskillz
    • 75
    Greetings!
    I have a Haier thermoelectric cooler that will not cool. The fans may twitch or come on at a lower speed, but the peltier cooling module will cool.
    I read this thread, but I still haven't been able to find the cause of the problem.
    The power output seems to vary greatly for no apparent reason. I'm getting everywhere from 2-17VDC from the output terminals. When I start to draw current with a load, regardless of whether it's a fan or the peltier module, the voltage drops drastically. When this happens, I hear what sounds like dripping water (or arcing) coming from the area with the two largest capacitors.
    I went over everything several times with a lighted magnifier, but don't see any signs of burnt or damaged components.
    Is there something I may have overlooked that may cause the output voltage to vary so much? It varies even after I remove the load.
    I've replaced all the electrolytic capacitors. I also tried swapping out the 13005-2 rectifiers. I swapped out the LM358P Op Amp, too.
    For some of this soldering, I was left with only a cheap 30w soldering iron from Radio Shack. Please excuse some of the butchering that may be apparent in the solder-side pictures.
  • digge
    • Apr 2006
    • 296
    Re: Haier Thermoelectric Cooler - Power Supply Output Anomaly
    That board looks very similar to one I've worked on in the past (some cheap-ass Chinese whine cooler in my case). I think i swapped all of the caps, and if memory serves me right i also swapped some of the "3 legged components" as well, the two that sits in a pair. Cant see what components they are from your pics though.
    Ofc you might have a different problem with that board then i had though
    • bobbyskillz
      • 75
      If you mean the two that are side-by-side on the aluminum heatsinks, they're 13005-2 (TO-220) transistors. I only had one of these in my parts chest, so I first soldered it in place of one, had the same results, then put it in place of the other.
      The strange thing I noticed about these transistors is that one of them has a plastic insulating washer between the screw and the heatsink. It also has a rubber pad behind it. I suppose it's there to insulate it. The other one has neither the plastic washer nor the rubber pad.
      • digge
        • Apr 2006
        • 296
        Those are the ones i meant. Im not an electronics engineer though so the package names and stuff is not my strong side Did the swapping do any difference at all? Like did it sound in another way or anything?
        If i remember tomorrow ill look for the order confirmation on the parts i ordered for it.
        • bobbyskillz
          • 75
          If it had any impact on it, I think it was a detrimental one. If I recall correctly, the voltage was even lower at the output.
          I sincerely appreciate your input on this!
          • bobbyskillz
            • 75
            I've gone ahead and ordered a new board. I blew up those two transistors and don't feel like waiting for replacements. I'll have the new board tomorrow. I'll keep the old one around, in case I decide to order those transistors and retry a repair.
            Thanks for the help!
            • FrancescoV
              Onkyo HT-R390 no sound output, video output ok
              by FrancescoV
              Good morning everyone,
              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
              The firmware reported is the following:
              M:1.00/11107BLP
              D:?.??/????????
              O:1.00/11107AL
              The DSP firmware given the question marks seems corrupt.
              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
              05-11-2025, 02:59 AM
            • Jneub007
              Haier HVTB18DABB Wine fridge thermoelectric board - bad caps?
              by Jneub007
              Hi! Hope you can lend me some advice.
              I am attempting to repair a Haier HVTB18DABB thermoelectric wine fridge. Both fans work, but the temps are not changing in the dual zones. Upon inspection, I believe this cap (pictured) and possibly another may be the culprits - based on the base of the caps and what looks to be dried dark liquid at the base. Assuming that is abnormal?
              Do you agree and which product do you suggest replacing with?
              Very much appreciated! Let me know if more info needed. ...
              01-20-2025, 11:50 AM
              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
              by sam_sam_sam
              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
              I bought this from an eBay seller but unfortunately they only had one
              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
              I bought three of from them to also make battery packs with this output power limit in mind
              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
              04-23-2025, 05:50 AM
              Corsair CX750M [Model 75-002019] - burned output toroid inductor
              by momaka
              Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
              So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
              09-19-2021, 08:44 PM
            • CoppellTVRepair
              Troubleshooting PFC with SPC1012T not raising output
              by CoppellTVRepair
              It has been a long while since I posted here to ask anything....hope you can help.
              I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
              I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
              03-09-2025, 10:38 PM
