Dell GX280 \ LiteOn PS-5161-7DS question
  • Agent24
    I see dead caps
    • Oct 2007
    • 4979
    • New Zealand
    I've been trying to get a Dell GX280 going, but not having much luck.
    Motherboard is full of good Japanese capacitors, all look OK, and it POSTs fine with a separate PSU.
    PSU work so far is as follows:
    Code:
    REFDES	Brand	Series	Voltage	Capacitance	Dimension	Notes	Result
    C203	OST	RLS	10v	2200uF	12.5 x 20 mm	FAILED - 4 Ohm ESR	Replaced with Panasonic FR
    C206	OST	RLS	6.3v	2200uF	10 x 20 mm		Replaced with Panasonic FR
    C283	OST	RLS	10v	2200uF	10 x 25 mm		Replaced with Panasonic FR
    C285	OST	RLS	10v	2200uF	10 x 25 mm		Replaced with Panasonic FR
    C223	OST	RLS	16v	1200uF	10 x 25 mm		ESR OK, left in for now
    C503	Ltec	LZG	10v	1000uF	8 x 20 mm		ESR OK, left in for now
    C504	Ltec	LZG	10v	1000uF	8 x 20 mm		ESR OK, left in for now
    C510	OST	RLS	10v	470uF	8 x 12 mm	FAILED - 2.4 Ohm ESR	Replaced with Rubycon ZL
    Machine starts but flashes power light orange with the LiteOn PSU. Sometimes it seems like it gets into a reboot loop, and the light flashes sporadically.
    Any known issue with this model of PSU other than bad caps?
    -David VanHorn
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Re: Dell GX280 \ LiteOn PS-5161-7DS question
    Is this the sff version? I think i have one of those PSUs, but mine has mostly teapo, Nichicon and Rubycon.
    I can put text here?!
    • Agent24
      I see dead caps
      • Oct 2007
      • 4979
      • New Zealand
      Yeah it's an SFF one.
      -David VanHorn
      • Agent24
        I see dead caps
        • Oct 2007
        • 4979
        • New Zealand
        I've found something else odd. The PSU won't start by jumping PS_ON to GND (even with an old HDD connected for load) - Some stupid Dell weirdness going on there or an actual fault?
        Looks like something weird is going on, seems like the reboot loop is actually the PSU resetting itself, after being on for a few seconds. I can even hear a little tick when it does, and see a voltage glitch on the output.
        So I guess this is some variant of a 'power cycling' problem...
        Also, while the output voltages look OK, it doesn't seem like the PSU is generating the Power_Good signal straight away. This probably explains why no board connected to it will POST.
        It does however seem to try to output a Power_Good signal after it goes into the ticking\cycling mode.
        -David VanHorn
        • retiredcaps
          • Apr 2010
          • 9271
          See if you have a similar/same power supply as my thread.
          https://www.badcaps.net/forum/showth...highlight=grey
          --- begin sig file ---
          --- end sig file ---
          • Agent24
            I see dead caps
            • Oct 2007
            • 4979
            • New Zealand
            Yours was listed as a "5161-7DS" which matches mine, so I assume it's the same one.
            But it is strange that worked for you, because according to the official ATX PSU specification:
            PWR_OK is a “power good” signal. It should be asserted high by the power supply to
            indicate that the +12 VDC, +5VDC, and +3.3VDC outputs are above the under-voltage
            thresholds listed in Section 3.2.1 and that sufficient mains energy is stored by the converter
            to guarantee continuous power operation within specification for at least the duration
            specified in Section 3.2.11, “Voltage Hold-up Time.” Conversely, PWR_OK should be de-
            asserted to a low state when any of the +12 VDC, +5 VDC, or +3.3 VDC output voltages
            falls below its under-voltage threshold, or when mains power has been removed for a time
            sufficiently long such that power supply operation cannot be guaranteed beyond the power-
            down warning time.
            I assume the Dell PSU does (or should do) the same thing. It seems odd that the motherboard works with a normal ATX supply, if the Dell one is non-standard.
            If I understand this properly, even if it was non-standard, why would they totally change the functionality of that signal to effectively the reverse of normal? I am not sure that the loss of PWR_OK signal is not a fault symptom... after all, it starts when connected to a board, just won't let the thing even attempt to start.
            And I DO get some voltage showing on the PWR_OK line, on a "normal" ATX board, fluctuating up and down when it's cycling. Very strange.
            -David VanHorn
            • retiredcaps
              • Apr 2010
              • 9271
              I have a personal hate-on for Dell and as such I rarely bother to research/learn what they are doing. If you weren't a badcap longtime member, I would not have even bothered to respond to a Dell thread.
              I stripped all the Dells down for parts and fooled around with the power supplies just to see if they work. I recapped only the obviously bulged caps just for "fun" with used capacitors (Capxon brand ) . I have no use for them as they are non standard form factor and only keep them around for potential parts or learning purposes in the future.
              Other than that, I try not to have any Dell products, even free ones, at home.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4979
                • New Zealand
                I don't like Dell (or any 'brand name' PC) much either. Far too much proprietary rubbish in their products and it seems like the reason is only "because they can" rather than anything sensible.
                This is the first full Dell system I've had (it was free which is why I even bothered to keep it) - At first glance I thought some new capacitors would solve its problems but now looks like it might be more trouble than it's worth...
                -David VanHorn
                • retiredcaps
                  • Apr 2010
                  • 9271
                  If you really want more ideas/suggestions, maybe head over to
                  http://en.community.dell.com/
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4979
                    • New Zealand
                    Thanks, might have a look, at least it may clear up how the PWR_OK signal is supposed to work on this PSU...
                    -David VanHorn
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4979
                      • New Zealand
                      No luck on Dell forums, but that's no surprise.
                      Anyone have suggestions for troubleshooting the POWER_GOOD signal?
                      -David VanHorn
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4979
                        • New Zealand
                        Found a schematic.. or rather, half of it. Seems like there's a bit missing.
                        -David VanHorn
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Yeah, I don't see the logic/PS_ON/PWR_OK circuitry in there.
                          Since the PC works fine with a regular PSU, I wonder if there is a way too fool the PWR_OK signal on that original PSU with a simple circuit. If it needs to be high when the motherboard is on, then simply connect it with a 1k resistor to the 3.3V or 5V rails. If it needs to be low, then use an inverting op-amp or something similar to invert signal.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4979
                            • New Zealand
                            That might work, but there still must be a fault, and I don't know that it would fix it.
                            The signal does come up, just not straight away, and when it does come up, the PSU has gone into a power cycling state.
                            The thing is I don't know if it's the POWER_GOOD signal circuitry that's at fault, and there's nothing wrong with the PSU, or if the PSU is really faulty, and this madness with the signal is because of it.
                            -David VanHorn
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              That I can't tell you.
                              Do you have pictures of the PSU by any chance?
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4979
                                • New Zealand
                                Not at the moment, I'll take some today and post them
                                -David VanHorn
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4979
                                  • New Zealand
                                  Some eye candy...
                                  For the record:
                                  Main PWM control is a UC3845BN
                                  5v Standby is done with a TNY266PN
                                  Supervisor IC is a Weltrend WT7515
                                  -David VanHorn
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Is the PG/PWR_OK wire directly connected to the WT7515? Looks like it is to me. Check if there are any resistors between in and ground or 5V that and make sure they are alright.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4979
                                      • New Zealand
                                      Looks like the startup capacitors were the problem.
                                      Code:
                                      C501	OST	RLS	35v	100uF	8 x 12 mm	22 Ohm ESR - 58uF
                                      C308	OST	RLG	50v	10uF	5 x 11 mm	38 Ohm ESR - 7.3uF
                                      C302	OST	RLG	50v	6.8uF	5 x 11 mm	23 Ohm ESR - 4.9uF
                                      Replaced C501 with a 150uF 35v Panasonic FC and other two with 10uF LTecs from another PSU that I recapped - only 1.5 Ohm each, MUCH better. Fine for testing anyway. Now I'll see how this thing goes, if it's OK, I might do 'proper' replacements.
                                      ALSO: It now starts on the bench by pulling PS_ON to GND, previously it wouldn't even do that.
                                      -David VanHorn
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        Wow, that 10uF cap has nearly 40 Ohms ESR!
                                        The again, these PSUs probably run quite hot. No surprise if even Japanese caps get cooked in there (granted, it will probably take them much longer).
                                        I guess the small caps even in these regular PC PSUs should never be underestimated. Learning something new everyday. Good job on the repair, by the way .
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
                                        • cheeky2
                                          Dell XPS One 2720 AIO Liteon PS-3261-9DA not starting up immediately
                                          by cheeky2
                                          I suspect the issue is with the power supply Liteon PS-3261-9DA as apparently they are notorious for issues with them. Has anyone else had similar issues where the PC tries to boot up a few times before finally booting up. Now I have opened up the PSU which shows no signs of any capacitors failing. I did remove one capacitor that looked to have an issue however with my peak meter it showed it was within the limits with good very low esr values which was somewhat disappointing!
                                          I am going to put a Meter leads across the outputs to see how stable they are when it occurs to see what they are...
                                          11-20-2024, 06:52 AM
                                        • diamon
                                          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                          by diamon
                                          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                          Pictures of these boards:
                                          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                          Dell...
                                          02-28-2024, 12:51 PM
