MSC60028 Output Inductor & Current Sense Resistor
  • japlytic
    • Oct 2005
    • 2086
    I happened to find that the MSC60028 was the only PFC chip available from my supplier.
    Two problems I encountered when calculating for an active PFC for a 400W and a 500W power supply were:
    • The current sensing resistor (2.2 ohms) in Figure 5 of the MSC60028 datasheet needs to be a value that gives a peak voltage of 0.3V across it under minimum load conditions (Page 9 of datasheet).
    • The values of Poutmax, fPWM, and L on Page 9 are a bit confusing, because the units of measure have not been specified e.g. A, kHz, mH.
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: MSC60028 Output Inductor & Current Sense Resistor
    Got a datasheet linky?
    You can't get a TI (Unitrode) UC3854?
    PeteS in CA
    • japlytic
      • Oct 2005
      • 2086
      http://www.alldatasheet.com/datashee.../MSC60028.html - MSC60028 datasheet.
      I can't get a UC3854 from my supplier.
      • japlytic
        • Oct 2005
        • 2086
        Found the calculations for the boost inductor on the UC3854 (had units of measure ) were about the same as the MCS60028.
        Boost Inductor
        Ip=Peak inductor current in A
        Poutmax=Maximum output wattage
        Vout=Output DC voltage
        Vinmin=Minimum DC voltage after bridge rectifier (multiply AC input voltage by 1.414 to get DC voltage)
        fPWM=PWM frequency in Hz.
        iL=Ripple Current in A (0.2 * Ip)
        Capacitor Selection
        T=Holdup time in mS
        V2outmax=Maximum output voltage threshold
        V2outmin=Minimum output voltage threshold
        C=Capacitor in uF.
        Current Sense Resistor (not shown on datasheet)
        Vrs=Normal Current Sensing Voltage
        Vrs(pk)=Peak Current Sensing Voltage
        0.3V under minimum load conditions
        I still need help with the current sensing resistor calculation to obtain 0.3V across it when the supply has a minimum load.
          Corsair CX750M [Model 75-002019] - burned output toroid inductor
          by momaka
          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
          09-19-2021, 08:44 PM
        • Darren Hibbert
          Replacing a Current Sense Resistor
          by Darren Hibbert
          Hi.
          Quick question.
          I have a laptop that is completely dead. I opened it up and it looks like the current sense resistor is blown. However, because it's blown, the value printed on the top has disintegrated and there is no schematic available for this particular laptop (Dynabook Portege) so I'm not sure what to replace it with.
          04-08-2024, 08:36 PM
          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
          Based on Intersil's Robust Ripple Regulator...
          11-05-2024, 03:24 PM
          ISL95836 Laptop PWM Controller Datasheet
          The ISL95836 Pulse Width Modulation (PWM) controller IC
          provides a complete solution for IMVP-7/VR12 compliant
          microprocessor and graphic processor core power supplies. It
          provides the control and protection for two Voltage Regulators
          (VRs). The first VR, typical for Vcore, incorporates 2 integrated
          drivers and can operate in 3-, 2- or 1-phase configurations. The
          second VR, typical for graphics, incorporates 1 integrated
          driver and can operate in 2- or 1-phase configurations. The two
          VRs share...
          11-05-2024, 03:31 PM
          MT3608 Step-Up Converter IC Datasheet
          The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
          Internal soft-start results in small inrush current and extends battery life.
          The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
          10-07-2024, 05:02 AM
