MSC60028 Output Inductor & Current Sense Resistor
    I happened to find that the MSC60028 was the only PFC chip available from my supplier.
    Two problems I encountered when calculating for an active PFC for a 400W and a 500W power supply were:
    • The current sensing resistor (2.2 ohms) in Figure 5 of the MSC60028 datasheet needs to be a value that gives a peak voltage of 0.3V across it under minimum load conditions (Page 9 of datasheet).
    • The values of Poutmax, fPWM, and L on Page 9 are a bit confusing, because the units of measure have not been specified e.g. A, kHz, mH.
    Re: MSC60028 Output Inductor & Current Sense Resistor
    Got a datasheet linky?
    You can't get a TI (Unitrode) UC3854?
    PeteS in CA
      http://www.alldatasheet.com/datashee.../MSC60028.html - MSC60028 datasheet.
      I can't get a UC3854 from my supplier.
        Found the calculations for the boost inductor on the UC3854 (had units of measure ) were about the same as the MCS60028.
        Boost Inductor
        Ip=Peak inductor current in A
        Poutmax=Maximum output wattage
        Vout=Output DC voltage
        Vinmin=Minimum DC voltage after bridge rectifier (multiply AC input voltage by 1.414 to get DC voltage)
        fPWM=PWM frequency in Hz.
        iL=Ripple Current in A (0.2 * Ip)
        Capacitor Selection
        T=Holdup time in mS
        V2outmax=Maximum output voltage threshold
        V2outmin=Minimum output voltage threshold
        C=Capacitor in uF.
        Current Sense Resistor (not shown on datasheet)
        Vrs=Normal Current Sensing Voltage
        Vrs(pk)=Peak Current Sensing Voltage
        0.3V under minimum load conditions
        I still need help with the current sensing resistor calculation to obtain 0.3V across it when the supply has a minimum load.
