Imac late 2006 psu 614-0380
  • Sylvester
    • Nov 2006
    • 67
    Imac 17" late 2006 cd MA710xx/A, psu 614-0380.
    Mac won't power up, nothing, as some of you will know its not easy to strip down, anyway,got to the psu,no obvious signs of bulging although the 120uF 450v had some goo on one leg, I'm not sure of the value of the other 3 caps.
    What is the best way to test this psu, I'm not sure if the logic board has leds on it, bearing in mind the front of the case comes off unlike the earlier ones that the rear came off?
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Imac late 2006 psu 614-0380
    I don't know if those are ATX PSUs or not... If they are, the best way to test is by shorting PS_ON to ground and checking all of the voltages.
    • PeteS in CA
      • Aug 2005
      • 3579
      • USA, Unsure of Planet
      Desktop Mac P/Ss ca. 2002 were basically ATX, with the -5v pin of the 20-pin connector being +3.3V instead. Also, the O/P harness was much longer.
      PeteS in CA
      • Sylvester
        • Nov 2006
        • 67
        Apple can be confusing, its not the desktop but the flat panel all in one mac, the output side has a 5 pin plug,
        AcBel AP150T61 psu 614-0380
        • Toasty
          • Jul 2007
          • 4171
          Hook it up to power and see if you're getting 12vdc. If not, try a small load across it such as an automotive marker lamp. These react when a load is presented, but should at least be giving you 12v when measured. (Voltage may "wobble" a bit because of no load.)
          T
          BTW - show a pic of the "goo" on the mains cap. Also, aren't there 5 caps plus the mains one?
          EDIT: FYI - It's API5OT61 - api5ot61
          veritas odium parit
          • Sylvester
            • Nov 2006
            • 67
            The goo was on the leg that was insulated as it went into the cap, I did think it resembled flux but there's no reason for it to be there, no obvious signs of swelling, prob better to check for 12v but not sure how to check on this one.
            Got me on that typo!
            • Toasty
              • Jul 2007
              • 4171
              Stick the probes in the connector until you get a reading...
              Black should be ground(-)
              Still no pics to go by....
              T
              veritas odium parit
              • Sylvester
                • Nov 2006
                • 67
                Used a 12v test lamp on the leads, nothing, using a meter on the leads basically nothing .02v.
                There are only 3 caps 1 is 1000uF 16v, I can't read the other 2 ( they appear ok), 1 small cap at the side 68uF 25v, and the mains cap 420v 120uF.
                • Toasty
                  • Jul 2007
                  • 4171
                  I'd say the mains cap is bad. It appears to be electrolyte leakage at that leg.
                  Check voltage input at bridge rectifier - AC
                  Check voltage output at bridge rectifier - DC
                  Check voltage across mains cap - DC
                  Report findings please.
                  Check fuse(s) - brown square device at mains input area.
                  Thanks for the pics!
                  T
                  veritas odium parit
                  • Sylvester
                    • Nov 2006
                    • 67
                    Sorry for the delay in posting voltages but there seems to be differing voltages between meters.
                    Fuse is ok.
                    Bridge ac 230v
                    Bridge dc 335v on dmm and 600v on analog meter
                    Mains cap dc 335v on dmm and 600v on analog meter
                    do they make sense?
                    • Toasty
                      • Jul 2007
                      • 4171
                      Sounds like the analog has a problem.
                      230v x 1.414 = 325v which is close enough as your AC reading or DC reading is probably off a bit either way. The voltage across the cap would be correct until the unit was actually under load, at which time I would be looking for upwards of 390v. PFC boost voltage.
                      Where are you located? Would you update your profile? From the 230v, I'm guessing it's not the US.
                      My next step would be to replace the small cap. The mains cap "leakage" has me concerned, but without the ability to test it, leave it for now. The fuse intact and no obvious burned components would also lead me to believe the boost section is okay.
                      T
                      veritas odium parit
                      • Sylvester
                        • Nov 2006
                        • 67
                        Updated profile, replace the 68uF 25v?
                        • Toasty
                          • Jul 2007
                          • 4171
                          Yes.
                          veritas odium parit
                          • Sylvester
                            • Nov 2006
                            • 67
                            May have one, failing that, tuesday.
                            Maybe even a new dmm
                            • Toasty
                              • Jul 2007
                              • 4171
                              Something close? Higher voltage is okay @ 47/56/82/100 uF.
                              Two lower voltage in series (capacitance divides) - e.g., (2) 100uF @ 16v in series = 50uF@32v.
                              T
                              veritas odium parit
                              • Sylvester
                                • Nov 2006
                                • 67
                                68uF 25v cap replaced
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  And...?
                                  veritas odium parit
                                  • Sylvester
                                    • Nov 2006
                                    • 67
                                    Plugged it back into mobo but nothing, I'll try it with the test lamp and see if there's any change
                                    • Sylvester
                                      • Nov 2006
                                      • 67
                                      No change from the original, bridge dc is 325v, 335v was probably a mistake on my part with the reading
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        Okay. Hmmm...?
                                        Try removing that shield from the foil side as it hides 50% of the components. Another pic like #14 above with good lighting & no glare, please. Nice and sharp.
                                        Start looking for torched resistors or transistors.
                                        What are the 2 components mounted to the heatsink next to (1) the mains cap, and (2) on the other side under the lip next to the 2 blue caps? Report markings please.
                                        Inspect and verify the value of the large (2 watt?) green resistor next to the mains cap.
                                        T
                                        veritas odium parit
