iMAc 27 inch late 2013 EMC 2639 no boot
  • Sergio Kub
    • Jul 2018
    • 172
    • Brasil
    Hello, I have an iMAc 27 inch late 2013 EMC 2639 at work that doesn't start, it has a prohibited symbol and/or when I connect the system via USB it stops on the apple.
    Is this feature locked in the bios?
    Thanks in advance​
  • pdblues2231
    • Jun 2022
    • 38
    Hi there,
    That does not seem like a bios situation, more like an OS problem.
    • Sergio Kub
      • Jul 2018
      • 172
      • Brasil
      Yes, it can't load the OS, but I put an external SSD on USB with High Sierra and indicated on the keyboard to start with it and it stuck on the Apple logo... Maybe GPU?
      • pdblues2231
        • Jun 2022
        • 38
        hi,
        Is that a 14,2? make sure you are using Catalina or below.. before you start experimenting with the gpu.
        • Sergio Kub
          • Jul 2018
          • 172
          • Brasil
          Yes, I tested with an external SSD on USB with High Sierra and it hangs on the Apple logo.
          I think I'll try a reflow on the GPU and it works, reballing
          • pdblues2231
            • Jun 2022
            • 38
            Ok. Great. Let me know if it works.
            • kevingill
              • Jun 2013
              • 152
              • England
              I doubt it's the GPU. It would just reboot.
              Looks more like a bad installer. Try a fresh Catalina USB installer stick.
              • Sergio Kub
                • Jul 2018
                • 172
                • Brasil
                Ok. So, I'll try to install native OS, via the internet.
                Then I'll post the result here​
                • Sergio Kub
                  • Jul 2018
                  • 172
                  • Brasil
                  After installing the OS via the internet, it restarted and crashed at the logo
                  • pdblues2231
                    • Jun 2022
                    • 38
                    have you cleared all of the nvram and smc.. also have you tested your ssd. if all else fails, then there is likely a hardware failure that is not being detected by the internal diagnostics. are you able to read the install log?
                    • kevingill
                      • Jun 2013
                      • 152
                      • England
                      Try taking out a stick of RAM one at a time to see if it's that causing the problem.
                      Also run ASD to check the iMac fully.
                      • Sergio Kub
                        • Jul 2018
                        • 172
                        • Brasil
                        I will do these procedures, thank you.
                        The iMAc crashes at the beginning, it doesn't reach the password screen or the desktop.​
                        • leovalpo
                          • May 2014
                          • 14
                          • chile
                          You can do these tests:
                          1. Turn on the iMac and press and hold the D key to start diagnostic mode, if it does not load, turn off the iMac.
                          2. Press and hold the shift key (⇧) to boot into safe mode, if it doesn't work, turn off the iMac.
                          3. With the IMac turned off, hold down Command (⌘) + R, press and release the power button, and continue holding Command (⌘) + R until the macOS built-in recovery system appears.
                          4. If you can access the macOS recovery system, locate the Utilities menu in the top bar and click on Terminal in the submenu.
                          5. When you are in the Terminal window, type date and press enter and write down the date/time, make sure it corresponds to the current date/time. If it is on a very late date/time, the system will not load, you can update the date/time using the same date command in Terminal:
                          date 1022130016 and hit enter.
                          date (month) (day) (hour) (minutes) (year)
                          6. If you cannot access it with the previous method, you will need a boot disk. It can be macOS Catalina, Mojave or High Sierra. If this is the case, turn off the iMac.
                          7. With the iMac turned off, insert the macOS installer into one of the USB ports and press and hold the Option (⌥) or Alt key to load the Boot Manager. Turn on the iMac and hold the key combination until the boot manager appears and select the external drive (macOS installer) that you previously inserted.
                          If the installer does not appear, while you are in the boot manager, remove the installer and plug it into another port until it appears, then select it to boot from that drive.
                          Once it loads, you will reach the external installer macOS recovery system, repeat steps 4 and 5 above.
                          8. If you don't have a compatible installer for this iMac, you can try pressing Command (⌘) + S at power-on to make it boot into Terminal mode. If you can get to this mode, go to step 5 to check the date/time, if it is behind, update with the commands that I wrote down, if you cannot change the date/time in this mode, you could try deleting the user's account, this We leave the last one for another occasion so as not to prolong these tests.
                          Previous considerations:
                          If you use a wireless keyboard, make sure the batteries are charged.
                          If you use a wired keyboard and do not take any key combinations, make sure that the iMac does not have a firmware password activated, if this is the case, the keyboard will not work and you will not be able to do any of the above.
                          Good luck!​
                          • Sergio Kub
                            • Jul 2018
                            • 172
                            • Brasil
                            - Replaces the SSD and recovers the system via the internet and continues with the prohibited logo.
                            - I reinstalled the operating system with a High Sierra installation pen drive, it stuck on the Apple logo.
                            I did the Apple diagnosis by pressing "D" and it only showed a possible defect in the camera.
                            I tried to start with an external HD containing High Sierra and it crashed.
                            I tried to start safe mode, with shift pressed and it stuck.
                            I will now examine SSD sources and signals.​
                            • leovalpo
                              • May 2014
                              • 14
                              • chile
                              You may need to perform tests using a different power source than the original one as the failure may be related to that part.
                              Replace the power supply and it should work​
                              • kevingill
                                • Jun 2013
                                • 152
                                • England
                                Did you try CMD-S terminal mode? You need to power up without using the graphics card. I thought safe mode would do this, but it seems not.
                                I think that since you've re-installed MACOS, but it then crashed whilst starting up indicates that the graphics card is faulty.
                                I've seen some complete boards on eBay for around $40.
                                • pdblues2231
                                  • Jun 2022
                                  • 38
                                  hi, there
                                  any solution with your problem?? Sergio.
                                  • Sergio Kub
                                    • Jul 2018
                                    • 172
                                    • Brasil
                                    No, still defective. Today I was unable to continue researching the defect, but I came to the conclusion that it is nothing related to the SSD, as I tried to boot with an external High Sierra SSD connected to the USB port.
                                    • liverkop
                                      • Aug 2023
                                      • 17
                                      • thailand
                                      Good luck!
                                      Good Guidelines​!
                                      • pdblues2231
                                        • Jun 2022
                                        • 38
                                        hi, there
                                        this is quite strange. it almost seems like a memory issue so its logical to conclude that there is a board problem. are you able to acquire another board and try swapping parts.
