PSU with bad caps straight out of the box!!!
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    I got this unit cheap, so it wasn't worth returning to the store but what the hell? It smells brand new from the factory. I brought this home and took it out of the box and opened it up (warranty sticker wasn't broken) and 4 caps are bulged!!! All of them are GoldLink caps... This looks like a Macron Power unit...overall it looks pretty well built. But look on the input......Why is one of the Y cap leads going to a hole that was meant for a resistor? two 30A parts for 5V, 16A for 3.3V and 30A for 12V and it has a Power Logic DC Brushless fan
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8670
    Re: PSU with bad caps straight out of the box!!!
    I'd assume some of the parts are hand assembled, I wonder if someone missed a hole. I wonder where that resistor lead connects to...
    In any case, yeah the caps probably succumbed during burnin...
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I will check it out when I take the PCB out of the case, I just found it strange....cause it's not just one, it's 4!
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        This PSU is very limited in Wattage, and even if you repair it, it would be capable to push a seven years old PC.
        Does it worth the trouble and parts ?
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          I think it's a pretty well built for a budget power supply. I think it's capable of 300W
          • Heihachi_73
            • 713
            0522. That thing is eight years old.
            • c_hegge
              • Sep 2009
              • 5219
              I've seen this before with Fuhjyyu caps (where they fail straight out of the box)
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Good catch...
                Wow, what brand was the PSU?
                • Heihachi_73
                  • 713
                  It wouldn't matter, they were Fuhjyyu to begin with.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    I've seen it twice. One was a Bliss brand, the other was an Antec
                    • goodpsusearch
                      • Oct 2009
                      • 2848
                      • Greece
                      16Α @ 12v
                      30a @ 3.3v
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Originally posted by goodpsusearch
                        16Α @ 12v
                        30a @ 3.3v
                        Correct. My bad
                        Worth a recap though? The fan looks decent and the soldering isn't that bad
                        • goodpsusearch
                          • Oct 2009
                          • 2848
                          • Greece
                          Originally posted by Pentium4
                          Correct. My bad
                          Yes:
                          https://www.badcaps.net/forum/showpo...5&postcount=48
                          https://www.badcaps.net/forum/showthread.php?t=12348
                          https://www.badcaps.net/forum/showthread.php?t=22916
                            master hoarder
                            • May 2008
                            • 12164
                            • Bulgaria
                            I disagree here.
                            This is the famous MPT-301 platform. I have the same PSU labeled as Inno Power, rated for 300 Watts. Has slightly less parts, but I am sure it is capable of 300 Watts. It can actually run a Core i7 CPU provided you use integrated graphics (tried it and it works fine). At one point, I had it running a 107W TDP CPU (AMD Athlon 64 FX-57) along with a Radeon 9700 video card (about 50W TDP, uses 5V heavily). 12V rail never went under 11.99V with full load. I've used that power supply to test various other systems as well. Runs great with both 5V-based and 12V-based computers. Extremely stable. Spot for 12V rail filter cap is 12.5 mm and the rest of the caps are 10 mm - so plenty of options when doing a recap.
                            Only negative things I can think to say about it are that it's a half-bridge (so not very efficient) and that the 5VSB is 2-transistor. No critical caps used in this 5VSB design, though (which is good).
                            Those are excellent fans. Never seen one seized. I usually find them very well oiled right from the factory.
                            Mine had Fuhjyyu caps. Failed due to the fan (a Supperred) becoming seized.
                            Yes x2
                              by momaka
                              03-12-2025, 03:42 PM
                            • eryjus
                              by eryjus
                              05-10-2023, 11:21 AM
                            • Paxman_Swede
                              by Paxman_Swede
                              Hello!
                              01-14-2025, 09:51 AM
                            • captain150
                              by captain150
                              03-16-2025, 07:34 PM
                            • Foetuss
                              Gigabyte GA-6OXT :: caps question
                              by Foetuss
                              Good evening
                              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                              But I was also suprised about the bigger boys, which are 330µF 25V.
                              Could it be they used 25V caps because they were cheaper / available at that time?...
                              02-11-2025, 12:22 PM
