PSU needing warmup to get to right voltage...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    I noticed my Power General open frame 40W PSUs doing something really peculiar: It's really well below rated voltage. It was dumping out around 4V on the 5V line, and 9.8V on the 12V line. It has an adjustment but even when turned up all the way, it still would not hit more than 11V on the 12V line.
    So I added another resistor in parallel with one of the voltage sense resistors (which is used as the input to a TIL431). With this resistor (I soldered it away from heat sources - more later) I was able to now adjust the PSU to get a full 5V on the output.
    However I now noticed something else that was peculiar : the voltage changed as the PSU apparently warmed up. When stone cold it was producing 4.5V and when it warms up, 5.35V(!) Likewise the tracking 12V went from 11V to 12.3V. These are no-load voltages (but the PSU was rated that it should be fine running under no load.)
    It appears the supply is using the TIL431 to regulate. The TIL431 is what drives the optoisolator that tells the UC3844 to lower the voltage.
    The "critical cap" that filters the UC3844's supply was replaced as it did fail. Since Vref of the UC3844 seems to be a solid 4.98V I think it should be OK, but I should go scope it and the power input just to doublecheck.
    I'm at a loss at what could have such a temperature variation. It has a couple of metal film resistors to set the voltage so those should be fairly stable. The only things I'm concerned about -
    the TIL431 being bad and temperature sensitive... ? I tried heating it with my solder iron and did not see a rapid voltage increase but I may not have heated it enough (plus it's too cramped in there...)
    other resistors (and the potentiometer) being temp sensitive after all these years?
    temperature capacitor leakage? There are no electrolytics I can see on this feedback circuitry, just some yellow inline "drop" capacitors (monolithic?). I can't imagine these to be under significant stress to fail... I might have to replace them with ceramics to see if it helps the issue.
    Anyone seen something like this and debugged it? I would suspect this is an age related problem, this PSU is around 25 years old now I'd guess. Unless it's one of those monolithic capacitors which I can't really test, the ESR of the other large electrolytics seem fine...
    Re: PSU needing warmup to get to right voltage...
    This is a pretty typical symptom of dried output capacitors, or a failing TL431.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      I just ruled out the TIL431 - replaced it and it still behaves the same. So it must be a dried cap. Odd that the ESR of the caps are fine but I didn't check leakage or capacitance...
      Just that I need to remove them from the board to test... and I don't have any spares
      (They're all Chemicon SXF including the 35V 39uF cap I replaced already...) Unfortunately I had to replace with a 47uF...
      • cheapie
        null
        • Jul 2010
        • 849
        That sounds like a startup cap - higher capacitance shouldn't hurt anything.
          • Jul 2011
          • 6070
          Here Is what I have found
          You need to test these caps at a temp at about 50*F and take an ESR reading then warm the same cap to 90*F if you ESR reading is more than
          10% of your highest reading to me this cap is bad
          When I replace caps that behave like this the power supply then works the way it should
          I have seen this problem at least 4 or 5 time in the last year
            • Jul 2011
            • 6070
            I have found that if the higher capacitance is more than 20% of rated value
            the next test is the ( temp test 50* F then 90*F) need to be done to see if that is more than 10%
            If you test a new cap the same way you will find that the difference is less than 2%
            • Fernon@Repair
              Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
              by Fernon@Repair
              i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
              VCCIO voltage ok
              VCCSA Voltage OK
              VCCPLL Voltage OK
              Ram Voltage ok
              RamVTT OK
              VPP 2.5 OK
              But No Core Voltage
              and i want to this vrm ic datasheet or pinout (ISL69269)
              anyone have this ic pinout voltages?...
              06-25-2025, 07:19 AM
              Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
              I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
              The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
              Now...
              06-09-2024, 10:57 AM
            • electron_jj
              Panasonic TH-L42D25A checking the PSU output voltage
              by electron_jj
              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
              08-29-2021, 08:13 AM
              ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
              3+1 Voltage Regulator for IMVP-7/VR12 CPUs
              Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
              core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
              configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
              serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
              Based on Intersil's Robust Ripple Regulator...
              11-05-2024, 03:24 PM
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
