Coba Power Supply
  • Togepi
    • Jul 2006
    • 8
    Coba Power Supply
    Hello
    This is my first Post. I had a Power Supply it is a Deer from 8/2001. Great up to this moment. Last night it Turned of... I will not Buy a Deer againt why? I have read any Posts here! In The Computer store the salesman say to me Buy a 400W A-Power (hmmmm But for 18€) I think it is Typical crap than i decided to Buy a Coba Power Supply. It is this but with 400Watt it is 420! Here a Picture: http://i15.ebayimg.com/02/i/07/bb/ee/98_1.JPG
    Was that a good Choice or not?
    Sorry for my Bad English.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Coba Power Supply
    external pic says nothing really
    • Togepi
      • Jul 2006
      • 8
      Yes, Sorry But i have no Cam. What i mean is is this (Coba) the Same label from a Cheap manufacturer. I have see the Manufacturer list but Coba is not included..
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        what is model and UL
        • Togepi
          • Jul 2006
          • 8
          The Modell is VP-420-S120 (P/PFC)
          The E-Number is E 100010
          Manufactured Date is 2005.
          Do you want the Ampere Datas Too?
          Whate you you mean with UL?
          Thx
          • Togepi
            • Jul 2006
            • 8
            great Finish!! The Power Supply Manufacturer is ATNG Power Co.LTD. Is that a good or a bad manufacturer?
            • Shroomie
              • Apr 2006
              • 356
              https://www.badcaps.net/forum/showpo...21&postcount=9 Well, there's one.
              I'd say it's a good bit better than Deer. Shouldn't blow up, anyway. (JonnyGuru says it's 'orange', which is overrated and not great quality, but at least safe.)
              You know there's something wrong when you open up a PSU and are glad to find Teapos.
              Why I don't buy cheap cases!
              • gonzo0815
                • Feb 2006
                • 1600
                Well, first nice to see another German on that side, well i am from the south too, but not from bavarian ;-).
                Any way, coba has got some good reputation in a test from the german it magazin C't wich i consider as one of the only magzins with som technically skilled people. But saidly, i bought a Levicom PSu for some time rated good at them, and if i open it up today, i duno how the C't was able to give it any rating. It has no VDE nor UL aproved Y & X caps, very few caps with low capacitance on all rails and all Fuhijyyu crap caps.
                I was tempted for myself to buy a Coba unit, but i looked at ebay and got some FSP350MDM, some Delta350w and some Seasonic SS400FS wich are all fairly good quality, well above anything you can get local in the range from lowest price to abouth 50€.
                So i suggest to look at some FSP350MDM on ebay, they are usually cheap, but shiping and handling are usually high. But you should get your hands on one for abouth 20€ to 30€
                They are decent build an will last at least abouth 100 000h wich is quite fine i think.
                I personally would prefer the Seasonic SS400FS, as it has active PFC and it is technically a very mature desing. But unfortunately, on some units they have used very poor caps on the 5v SB rail, thus they can bulg very early at normal ussage. But not all units are affeckted, and if you replace them, there is absolutely no issue with them. They are not very loud too, but ok the FSP is probalby a little less noisier, as it has an 12cm fan.
                If you ever decide to buy one, please do me the favor and open it for some nude pics
                • Togepi
                  • Jul 2006
                  • 8
                  Hm i have already bought this Power Supply 1Week ago. Yes i wil open the Power Suppy but there is a Warranty Sticker. Hmmm i think i dont't Opened the Suppy because i see the Startech ATNG Supply.
                  Thx for all your Answers!!
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • JimBanville
                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                    by JimBanville
                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                    09-13-2023, 07:21 AM
                  • CMCM
                    Russound CA4 Power Supply Repair
                    by CMCM
                    Hello Everybody,
                    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                    The outputs marked 12v and 20v are all measuring only 1v.
                    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                    The capacitors physically look clean (no bludgesor leaks) and...
                    07-03-2025, 01:12 PM
