thermaltake tr2 430w
My Computer.
AMD APU A4-3300 2.5ghz 1mb cache
Motherboard GigaByte GA-A75M-S2V
Kingston HyperX Blue DDR3 8GB (2x4GB)
SB Audigy 2 ZS [B800] Sound Card
500GB WD Caviar® Blue™
1 Terabyte WD Caviar® Black™
2 Terabyte WD Caviar® Black™Comment
Re: thermaltake tr2 430w
Well, Th3_uN1Qu3 has pulled 500W from a 35 size transformer before. And this review shows 470uF Capxon primaries (220V/105C) doing 350W with 76% efficiency at 115V (at 50C room temperature, too):
http://www.hardwaresecrets.com/artic...y-Review/1500/
So it is possible.
EDIT: I wouldn't want to risk it. But I have 300W Hipros with only 470uF primaries and they do 300W alright at 75% efficiency and continuously. Efficiency won't be fantastic but it can work.Last edited by Wester547; 10-06-2012, 12:17 PM.Comment
It's 10% possible or less. Would you risk blowing the psu and/or damaging the hardware connected? I wouldn't.Well, Th3_uN1Qu3 has pulled 500W from a 35 size transformer before. And this review shows 470uF Capxon primaries (220V/105C) doing 350W with 76% efficiency at 115V:
So it is possible.Comment
Ok, no prob! Either way I would replace the 1000uF caps with 2200uF or 3300uF.
I would also replace the 5vsb 470uF capacitor with 1000uF.
If momaka saw this, I am sure he would warn you about that resistor near the 5vsb capacitor. Try to bend the resistor away of the capacitor if you don't want it to cook the cap.
12V has actually only 1 cap and no coil. You might want to replace that 2200uF 16V cap with a 3300uF 16V cap.
Please post a nice picture of the solder side if it is possible.Comment
Do you mean that you think 470uF primaries can't do 300W continuously or do you mean 350W? Or do you mean 560uF primaries can't do 350W continuously?
And, alternatively, maybe you could bend (slightly) the capacitor away from the resistor.Last edited by Wester547; 10-06-2012, 12:34 PM.Comment
i marked the corner that is 12v had to open up the psu again i had just put it back in my computer.Attached Filesif you find these attachements useful please consider making a small donation to the site
i just replace one of the 470uf or all 3?Ok, no prob! Either way I would replace the 1000uF caps with 2200uF or 3300uF.
Please post a nice picture of the solder side if it is possible.My Computer.
My Computer.
I attached a pic with my suggestions. The cap circled is 85 Celsius cap. This is unacceptable for a power supply. You should replace it with 105C cap. I am not sure if this cap is for -12V or 5vsb. If it is responsible for 5vsb filtering along with the other 470uF I would advise you to put a 1000uF there too.
You better stick to the original voltage values. 6.3V can be replaced with 6.3V or higher Volts (10V, 16V).
10V -> 10V or 16V
16V ->16VAttached Filesif you find these attachements useful please consider making a small donation to the site
alright thanks a lot i dont know if ill be able to get this done anytime soon i put $25 on preload credit card the other day and i just found out tody they took $15 for a monthly fee i was really angry about it.Last edited by Phaihn; 10-06-2012, 02:30 PM.My Computer.
i am going to catalog the caps i have and see if i have the caps i need in my collection.My Computer.
ost 3300uf 6.3v x5
kmg 3300uf 6.3v x4
yec 1500uf 6.3v x6
nic 1500uf 16v x9
fu 1000uf 10v x5
ost 1500uf 6.3v x1
can 1500uf 6.3v x6
[A] 470uf 10v x7
Glux 470uf 16v x1
yec 470uf 16v x1
ost 1200uf 16v x3
sxe 2200uf 10v x2
yec 1000uf 6.3v x3
fu 470uf 10v x3
ost 1000uf 6.3v x3
glux 1000uf 6.3 x3
junfu 470uf 16v x1
kzg 820uf 6.3v x2
ost 2200uf 6.3v x1
kme 1000uf 16v x1
glux 1500uf 6.3 x2Attached Filesif you find these attachements useful please consider making a small donation to the site
My Computer.
The rule I use is 1uF/watt and is common in SMPS design (without PFC front ends.) Remember with two 470uF 200V in series, that's just 235uF... you're getting serious ripple on the primary, so the transistors have to pump more current through the transformer and the transformer needs a greater turns ratio.
It's much cheaper to use bigger caps and smaller transformer/transistors to get a higher output power, than a smaller cap and bigger transformer/transistors, so in general when I see small caps, I think small output power.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
are you saying i should use bigger primary caps?The rule I use is 1uF/watt and is common in SMPS design (without PFC front ends.) Remember with two 470uF 200V in series, that's just 235uF... you're getting serious ripple on the primary, so the transistors have to pump more current through the transformer and the transformer needs a greater turns ratio.
It's much cheaper to use bigger caps and smaller transformer/transistors to get a higher output power, than a smaller cap and bigger transformer/transistors, so in general when I see small caps, I think small output power.My Computer.
rubycon 820uf 6.3v x25My Computer.
Does that apply for the secondary too (hugely powerful rectifiers vs. smaller output capacitors vs. coils)? As in, it's much more prudent to have smaller rectifiers and bigger capacitors (in capacitance)/more coils on the secondary side in terms of filtering than largely powerful rectifiers and smaller capacitors (in capacitance)/less coils?The rule I use is 1uF/watt and is common in SMPS design (without PFC front ends.) Remember with two 470uF 200V in series, that's just 235uF... you're getting serious ripple on the primary, so the transistors have to pump more current through the transformer and the transformer needs a greater turns ratio.
It's much cheaper to use bigger caps and smaller transformer/transistors to get a higher output power, than a smaller cap and bigger transformer/transistors, so in general when I see small caps, I think small output power.Comment
No, it's far too variable with secondary design to be useful for that. It's just a basic approximation for non-PFC power supplies. Good designs use 1.5~2uF/watt. Antec used two 1200uF 200V in series (600uF) for a 350W power supply. Not saying Antec are any good, but at least the output power is probably honestly rated.Does that apply for the secondary too (hugely powerful rectifiers vs. smaller output capacitors vs. coils)? As in, it's much more prudent to have smaller rectifiers and bigger capacitors (in capacitance)/more coils on the secondary side in terms of filtering than largely powerful rectifiers and smaller capacitors (in capacitance)/less coils?
In general at high frequencies capacitance is less important: it's ESR which is the killer. Basically you want to dump all that high frequency to ground and get flat DC out. Lower ESR, less impedance for the AC. That's a basic view of the problem. I'm sure th3_un1qu3 will improve on it
So then... having low ESR/impedance/high ripple rating capacitors on the secondary guarantees stabler power and matters far more than having the highest uF rating?
And I always thought Antec rebranded PSUs, so whether their PSUs were good or not would depend upon who they're branding (whether it be Seasonic, Delta, FSP, etc...).Last edited by Wester547; 10-06-2012, 06:30 PM.Comment
by objecttothisI had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
by roddDear all,
I am trying to repair the ATX power supply.
First I fixed the +5V stby, which was zero due to a shorted TNY279 and an open 2R2 resistor.
Just in case I replaced the PWM control IC (PS223) and the PFC control IC (CM6800).
Now the supply turns on, the +3.3V is fine, but the +5V measures only 2.5V and there is no +12V.
I have checked every diode I could find with a DMM (in circuit) and all the capacitors (in circuit) no shorts, low ESR.
In despair I removed the low voltage diodes which were all mounted on the same heatsink... -
by AresROChttps://www.amazon.com/gp/product/B00NW6W2C8
I have a Thermaltake TR2 80+ Bronze that's been doing strange things. It would cause the computer to shot down randomly, and measures low voltage on the 12 volt rail. From 11.5 to 11volt.
I put it on the bench with a harddrive as load, and it outputs fine with low load:
5v - 5.17v
12v - 12.17v
It has all Japanese caps, but only 1 large cap for the Input supply. No obvious signs of overheating burns or bulge. Anyone know where I should start to troubleshoot? I guess I don't want to just start by replacing... -
by delturciousI have an older Thermaltake PSU that has a squealing noise whenever it's plugged in, even when totally disconnected from everything else. It automatically powers on the 5V and 12V rails with full voltage, but the +5VSB circuit only has 0.9V on it. I would assume this is my first place to start troubleshooting?
There is nothing obviously burnt/leaking that I can identify.
I've tried to take some decent photos of the 5VSB area. Components of notes:- U8 at the back is marked AZ431
- C38 is 102
- C47 is 104
- C34 is a Teapo 330uF 16V (I think all the cylindrical caps are
PSU: Thermaltake Litepower 500W Model: LT-500AL2NC
PCB: G08-CGPA462-PA00 Rev:A
I have this PSU installed in my PC for several years.
The problem is one day my PC cannot detect an external HDD so i think maybe the PSU caps already bad.
So i decided to open the case and found some of the secondary caps already bulging.
Then i recapping all the caps except the primary one (because i tested it with an esr meter and its still good) and i already tested all the new caps too before i soldered them.
After that the psu is good and my pc can... - Loading...
