thermaltake tr2 430w
  • Phaihn
    • Jan 2009
    • 842
    Re: thermaltake tr2 430w
    is there a list of the capacitors that are in my psu that i can use so i dont have to open it up i would like to buy some good panasonic capacitors for it so if anyone knows what goes in it and can make suggestions for improving upon it would be great.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
    • objecttothis
      EVGA 430W PSU Correct voltages but computer won't turn on
      by objecttothis
      I had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
      02-08-2025, 11:19 AM
    • rodd
      Thermaltake TR2 750W -fixed 5v stby now +5v reads low and no 12v
      by rodd
      Dear all,
      I am trying to repair the ATX power supply.
      First I fixed the +5V stby, which was zero due to a shorted TNY279 and an open 2R2 resistor.
      Just in case I replaced the PWM control IC (PS223) and the PFC control IC (CM6800).
      Now the supply turns on, the +3.3V is fine, but the +5V measures only 2.5V and there is no +12V.
      I have checked every diode I could find with a DMM (in circuit) and all the capacitors (in circuit) no shorts, low ESR.
      In despair I removed the low voltage diodes which were all mounted on the same heatsink...
      08-11-2023, 12:58 PM
    • AresROC
      Thermaltake TR2 Bronze 600w low 12v voltage
      by AresROC
      https://www.amazon.com/gp/product/B00NW6W2C8
      I have a Thermaltake TR2 80+ Bronze that's been doing strange things. It would cause the computer to shot down randomly, and measures low voltage on the 12 volt rail. From 11.5 to 11volt.
      I put it on the bench with a harddrive as load, and it outputs fine with low load:
      5v - 5.17v
      12v - 12.17v
      It has all Japanese caps, but only 1 large cap for the Input supply. No obvious signs of overheating burns or bulge. Anyone know where I should start to troubleshoot? I guess I don't want to just start by replacing...
      12-02-2021, 02:07 PM
    • delturcious
      Thermaltake ATX TR2-430 Turns on by itself, squeals, & has 0.9V on +5VSB
      by delturcious
      I have an older Thermaltake PSU that has a squealing noise whenever it's plugged in, even when totally disconnected from everything else. It automatically powers on the 5V and 12V rails with full voltage, but the +5VSB circuit only has 0.9V on it. I would assume this is my first place to start troubleshooting?
      There is nothing obviously burnt/leaking that I can identify.
      I've tried to take some decent photos of the 5VSB area. Components of notes:
      • U8 at the back is marked AZ431
      • C38 is 102
      • C47 is 104
      • C34 is a Teapo 330uF 16V (I think all the cylindrical caps are
      02-11-2021, 11:26 AM
    • sonicunderground
      Need Help Thermaltake Litepower 500W Problem
      by sonicunderground
      PSU: Thermaltake Litepower 500W Model: LT-500AL2NC
      PCB: G08-CGPA462-PA00 Rev:A
      I have this PSU installed in my PC for several years.
      The problem is one day my PC cannot detect an external HDD so i think maybe the PSU caps already bad.
      So i decided to open the case and found some of the secondary caps already bulging.
      Then i recapping all the caps except the primary one (because i tested it with an esr meter and its still good) and i already tested all the new caps too before i soldered them.
      After that the psu is good and my pc can...
      08-11-2020, 04:59 PM
