APC RS 800 capacitor issue?
  • kevin s
    • Sep 2012
    Hello all!
    I have 2 of the APC RS 800 units which I have purchased new batteries for but the UPS's show overload with 90 watts connected when going to battery power. It also shows the unit is charging and the % of charge is slowly dropping when it is on AC line power.
    I have search all over using google (which is how I found you folks) trying to figure out if it is a capacitor issue.
    The PCB is a 640-0189D and all the capacitors look normal with no swelling or leaking.
    Where is the charging capacitor? I have also read where it may be the inverter capacitor?
    My wife is not very happy with me having 2 UPS in pieces in the living room so any help would be great!
    Thanks!
  • MORETTIGIAN
    Capacitor detached from PCB – RTX 2070 Super Founders Edition
    by MORETTIGIAN
    Title:
    Description:
    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
    I did not notice it detaching, so I am unsure of its original location on the PCB.
    Procedure performed:
    - Removed backplate
    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
    - Reapplied thermal compound
    - Reassembled card
    Observed behavior after reassembly:
    - GPU powers on and operates normally under...
    09-18-2025, 12:14 PM
  • devsigner
    identify capacitor for MacBook Pro with rare logic board 820-02037-06
    by devsigner
    Hi
    While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
    resistance tests show a rising resistance value, indicating a capacitor.
    The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
    i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
    It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
    Yesterday, 01:39 PM
  • link626
    TCL 43s405 4k TV only runs on lower power mode. Sound like a capacitor issue?
    by link626
    I've gone through 2 of these power supply boards.
    Same issue on both. If I use TV at full brightness, full power, the screen will start blinking; go black once every 2 seconds.
    It was fine for months before exhibiting this issue.
    If I lower the brightness, and run it in low power mode, the blinking stops.
    Attached photo below is the board.
    Do you think this blinking is a capacitor issue?
    These are all HEC brand cheapo caps, except the 82uF which is YST brand.
    I cannot find spec sheets.
    07-29-2021, 07:11 PM
  • chth96
    If I replace with inferior capacitor, Is it No harm to other IC components at all?
    by chth96
    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
    I know that these capacitor will not last as long as nichicon capacitor...
    12-22-2023, 04:34 AM
  • chth96
    How can I test non-polarized capacitor?
    by chth96
    I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
    I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
    And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
    I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
    06-02-2024, 07:31 PM
