APC RS 800 capacitor issue?
  • kevin s
    • Sep 2012
    Hello all!
    I have 2 of the APC RS 800 units which I have purchased new batteries for but the UPS's show overload with 90 watts connected when going to battery power. It also shows the unit is charging and the % of charge is slowly dropping when it is on AC line power.
    I have search all over using google (which is how I found you folks) trying to figure out if it is a capacitor issue.
    The PCB is a 640-0189D and all the capacitors look normal with no swelling or leaking.
    Where is the charging capacitor? I have also read where it may be the inverter capacitor?
    My wife is not very happy with me having 2 UPS in pieces in the living room so any help would be great!
    Thanks!
  • MORETTIGIAN
    by MORETTIGIAN
    Title:
    Description:
    Procedure performed:
    - Removed backplate
    - Reapplied thermal compound
    - Reassembled card
    09-18-2025, 12:14 PM
  • link626
    TCL 43s405 4k TV only runs on lower power mode. Sound like a capacitor issue?
    by link626
    I've gone through 2 of these power supply boards.
    Same issue on both. If I use TV at full brightness, full power, the screen will start blinking; go black once every 2 seconds.
    It was fine for months before exhibiting this issue.
    If I lower the brightness, and run it in low power mode, the blinking stops.
    Attached photo below is the board.
    Do you think this blinking is a capacitor issue?
    These are all HEC brand cheapo caps, except the 82uF which is YST brand.
    I cannot find spec sheets.
    07-29-2021, 07:11 PM
  • chth96
    by chth96
    12-22-2023, 04:34 AM
  • chth96
    by chth96
    06-02-2024, 07:31 PM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
