Shame on you Corsair! (Capxon)
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    I suggested this power supply to a friend (Corsair Builder Series CX430 V2 430W) after reading reviews online and being aware that it uses non japanese capacitors, for example Teapo and Samxon. I am ok with those brands, they rarely fail. But, as you can see from the photos I took without voiding the warranty, there is at least 1 Capxon inside...
    Well, at least it offers a 3 year warranty... Let's see if it will be needed.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Shame on you Corsair! (Capxon)
    a friend brought one of those in a while back when the system acted up.
    wasnt the problem(bad hdd) but noted the crapxons.we know whats coming.curious to see how long it takes.
    • c_hegge
      • Sep 2009
      • 5219
      Corsair should indeed be ashamed!!
      Bear in mind that the samxons used in the CX430 are GF series, which are defective.
      I just took a Delta PSU from an Acer PC home. The caps were mostly Aishi and LTEC, but the one capxon (on the 5v rail) was vented.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        nooooooo that poor PSU. Hopefully it stays cool and doesn't die within the hour
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          Channel well technology sucks! First, they used fuhjyyu, especially in Antec branded psus.
          Now they use Capxon. Will they ever learn??
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            You bet!
            Or if not, it will probably last just a day over the warranty.
            Looks like that green CapXon (GL series??) is on the 5VSB rail. Great! So it's being under constant "stress" as long as the PSU is plugged in.
            I also saw that some of the other green caps had "GF" written on them. Samxon probably?
            Yes, I have a feeling we will be seeing these units back in for repair again. Corsair should be ashamed, indeed.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              This power supply costs 48euros. For that price I was expecting better...
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                I will open another thread later, with inside pictures, but after I researched a little, after a bunch of Corsair CX´s entered the shop, at least around here seems people are not liking them. Too much RMAs, some work for a few months then die, some will only work with some moderate to big load ( that is, will not work with a too lightweight computer ) , and the like.
                All Samxon caps, from what I saw.
                • mariushm
                  • May 2011
                  • 3799
                  CWT most likely has nothing to do with it. They're OEM, they will use the parts the buyer asks them to use, to bring the price down.
                  If you were the boss of CWT, would you give up on a 10k+ units contract just to stick to your capacitor selection?
                  Blame Corsair for deciding to save money on capacitor selection INSTEAD of cheapening out on input filtering and cables.
                  Other than this, the CX are only rated for 40C, not 45-50 as most power supplies. Personally, I didn't hear them failing due to capacitors but I did hear people complaining about coil whining.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    I blame both! What is the cost difference between Ltec/OST/Teapo and Capxon? I don't think it is worth it..
                    Actually it's 30°C:
                    http://www.jonnyguru.com/modules.php...Story&reid=239
                      I thought OST was crap too. Teapo, I've pulled a couple of them. Ltec - no experience myself, but I've seen the occasional one in monitors bulged on these forums.
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        They are all bad compared to Japanese aluminum capacitors, but still better than Capxon. I see them failing everywhere.
                          The number of CapXon I have pulled... I mean WHY do manufacturers still insist on using these? They are really terrible caps!
                          • Wester547
                            • Nov 2011
                            • 1268
                            • USA.
                            I always thought Fuhjyyu, Rulycon, and Evercon were the worst, though I suppose it's all anecdotal. I've heard people say that PSU companies like Delta have ways of making even Capxon capacitors last a while. I've also heard people say Capxon have improved over the years, though, in saying that, bad capacitors will always be bad capacitors, period. No exceptions.
                            Capxon will definitely fail when under stress (or in hot locations, right next to a heatsink, right next to a diode, on the 5VSB rail, etc), especially if 5VSB is always kept on. If not, they'll probably last longer, though how much is a debatable of sorts. And yes, efficiency also has to do with it, though low efficiency can also kill not only underpar capacitors but underpar components otherwise even quicker. What's scarier is that Capxon is also found as the choice of input capacitors, which means there's more of a potential for sparks, smoke, and explosions...
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Rulycon caps don't exist no more. And i've seen Fuhjyyu last more than CapXon. TV repair shops here like to use CapXon because they guarantee that the TV will be back in an year or two.
                              A working TV? How boring!
                                I suspect planned obsolescence is one part of the problem. Just like the Samsung LCD TVs which were lasting 1-2 months past the warranty due to bad Samwhas. It seems too consistent to be accidental.
                                I suppose that's why buying stuff broken and fixing it is so much more attractive for me. Then you can pretty much guarantee it will last a long while, a lot more than buying stuff retail. Almost everything I've got now has been bought as faulty and repaired, there are a few exceptions like my scope but those are hard to get faulty (they go for high prices due to high demand.)
                                • Rulycat
                                  • Apr 2010
                                  • 724
                                  • United Kingdom
                                  And after my Corsair USB 3.0 memory stick has started occasionally wiping itself (it's going back!) I think we can safely say that Corsair is off my "recommended brands" list.
                                    Many of these companies don't engineer their own products any more. This is a big problem, because they rely on the test data of the OEM who produces it. In China, a lot of this test data is, well... modified to suit the manufacturer. It is common practice to do so. I wish more products were consumer engineered in the UK and US, it would be nice to make them in the same countries too but that might be asking too much, but when everything nowadays is re-badged, this is what happens...
                                    • tleu8472
                                      • Dec 2011
                                      • 36
                                      Any idea if the Corsair CX500 V2 is any better?
                                      • proofinlife
                                        • Jan 2012
                                        Just a heads up to anyone buying the CX-430 :
                                        I ordered one late last year, I had it sitting in the box in the plastic for over 4 months. I installed it in a clients computer, and in less than an hour the psu failed, all rails but the 12v, nothing.
                                        I sent it in for RMA, they sent me a new one. I had it in a clients computer for no less than 6 hours, and the EXACT same problem occured. I have not RMA'd this one because corsair refuses to give me the option to upgrade to a different series.
                                        My workbench has a cyberpower UPS, so no dirty power can be the culprit. Antec's, Bestec's, LiteON's, etc have all been through here and not one issue.
                                        This leads me to believe corsair is putting pure filth in their builder series power supplies.
                                          Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) L Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 Yoga + 3YOS Warranty boardview and L13 Yoga + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 04:30 AM
                                          Lenovo ThinkPad L13 + 3YOS Warranty Notebook L Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad L13 + 3YOS Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 + 3YOS Warranty boardview and L13 + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
