Did anyone else notice this before???
  • Shocker
    Banned
    • Dec 2011
    • 635
    It has long been known that those silly 4700uF 10mm Fuhjyyus are bogus anyway. But I just noticed something. Looking at the Nichicon HM table...
    6.3V
    1500uF - 10mm x 12.5mm
    2200uF - 10mm x 16mm
    3300uF - 10mm x 20mm
    (smallest sizes for each value)
    So I figured...
    3900uF - 10mm x 25mm
    4700uF - 10mm x 30mm
    So it appears that it actually is possible to make 4700uF 6.3V caps in 10mm. (Yes, I know the Fuhjyyus mentioned are 10V, but surely it's not beyond Fuhjyyu to take 6.3V caps and label them as 10V...)
    Okay, so I have no idea how they managed to make those 3300uF 16V 10mm SamXon RS. But that's another mystery for another day.
  • Rulycat
    • Apr 2010
    • 724
    • United Kingdom
    Re: Did anyone else notice this before???
    Surely if you were able to pull some unused Fuhjyyus you could test whether they were 10V by applying say 9.5V through them. I don't think the voltage rating would be bogus.
    • mockingbird
      • Dec 2008
      • 5484
      If you go by the logic that a reduction in width can always be compensated for by an increase in height - but we don't know that. It's been implied before, but you'd have to ask an actual engineer.
      Teapo also made "4700uf" 10mm caps that were really 3300uF caps (These are Teapo "SC" series, and the dimensions are 10x30 FYI). I've still got two of them from my SP450 re-cap, and they're not bulged. I'd like to test them someday if I ever get a meter.
      • Shocker
        Banned
        • Dec 2011
        • 635
        ...or would it??? You know what Fuhjyyu are like.
        I'm also willing to bet that the 3300uF 16V 10mm TMs are actually 2200uF.
        And there's also a 2200uF 6.3V 8mm TM specified. Maybe that's actually a 1500uF.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Lets not get talking about '470uF' 200v caps now
          Muh-soggy-knee
          • c_hegge
            • Sep 2009
            • 5219
            Nichicon and Panny also make 2200uF 6.3v caps in 8mm diameter
            • Shocker
              Banned
              • Dec 2011
              • 635
              I know, but Fuhjyyu TM isn't even close to HM and FJ.
              • b700029
                Banned
                • Sep 2010
                • 640
                Capacitance is directly proportional to the surface area of the plates, which given the same thicknesses/number of windings/same diameter is also directly proportional to the height of the cylinder.
                The vertical linear density for the 10mm 6.3V caps you've listed are:
                1500uF - 120uF/mm
                2200uF - 137.5uF/mm
                3300uF - 165uF/mm
                Using the 120uF/mm number to be conservative results in a 40mm high cap for 4700uF, while 165uF/mm results in 28.5mm.
                For the 10V HMs...
                1000uF 10 x 12.5 - 80uF/mm
                1500uF 10 x 16 - 93.75uF/mm
                1800uF 10 x 20 - 90uF/mm
                2200uF 10 x 25 - 88uF/mm
                ...resulting in a 10V 4700uF 10mm cap being between 58.75mm and 50.13mm high.
                Those 10x30 10V SC even at 3300uF would be 110uF/mm, which is a bit on the high side. 2700uF - 90uF/mm - seems much more reasonable.
                • mockingbird
                  • Dec 2008
                  • 5484
                  b700029 - Fantastic... Kudos to you.
                  • severach
                    • Aug 2007
                    • 1055
                    http://en.wikipedia.org/wiki/Capacitance
                    Capacitance goes up as the plates get closer but the voltage goes down. If you can improve the dielectric to resist more voltage you can make a higher uF cap in the same size package.
                    A DUOYI DY294 will tell you if they are cheating on voltage.
                    sig files are for morons
                    • Topcat
                      4700uF 6.3v and 3300uF 16v in a 10mm Diameter
                      by Topcat
                      Where can I get them these days? My usual sources are a no go in a 10mm, 12.5mm is too big. I'm recapping an old Antec rackmount PSU for a client (SmartPower SP2-450SXR) with a bunch of spooged Fuhjyyu crap caps, and he's insisting it be repaired....which is fine by me, I make more on it that way.....but I need to find these illusive caps....it's been a long time since I've needed these values....and now I can't find them. Odds are I could get away with 3300uf in place of the 4700uF, I've done it before...but if there's a source for them in 10mm, I'll try to stay original.
                      10-14-2020, 06:35 PM
                    • CWEastwood
                      Antec Smart Power SL300S capacitor replacement.
                      by CWEastwood
                      I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                      The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                      I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                      Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                      03-25-2023, 12:18 PM
                    • quickname
                      Cyberpower 1500AVR UPS repair
                      by quickname
                      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                      Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                      I decided to verify that the batteries were...
                      11-12-2023, 09:57 AM
                    • ssl6
                      MSI K7T266 Pro (Ver. 1.0)
                      by ssl6
                      Hey Everyone,
                      Long time lurker, but I think this is my first time posting.
                      Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                      I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                      11-09-2023, 01:00 PM
                    • jayjr1105
                      Need help with 4700uf 25v replacement in subwoofer
                      by jayjr1105
                      Bought a cheap sub on marketplace for $20. Has two 4700uf 25v Jun Fu 85c rated caps. I've found several replacements for around $1 or 2 but what ripple current rating should I shoot for minimum? Also they have to be 16mm wide and a max of 30mm tall, lead spacing is 7.5mm and they are through hole.
                      I am about to buy these just because they're cheap and 105c rated
                      https://www.arrow.com/en/products/47...er-electronics
                      Edit: add some bad 22uf 25v Jun Fu's to the list as well
                      05-07-2021, 08:13 PM
