Thermaltake Toughpower 750W ATX power supply
  • Maxpayne
    • Jul 2012
    • 5
    • Bangladesh
    This is output section of Thermaltake 750W ATX power supply.
    Can somebody explain what is the role of this ckt in +5V rail ?
    Two transistor forward topology is used here in the primary. I don't have the whole schematic, also looking for it
    My problem is in +5V section. Whenever I connect load on this rail the power supply shuts off itself. other two rail +12V and +3.3V is quite ok.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Thermaltake Toughpower 750W ATX power supply
    That schematic doesn't look quite right... as the transformer is center-tapped the dual diodes should have both ends connected to each side.
    • Maxpayne
      • Jul 2012
      • 5
      • Bangladesh
      This is right. I hv chked it..
      • Khron
        • Sep 2006
        • 1350
        • Finland
        Which 750w ToughPower model is it?
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
        • Maxpayne
          • Jul 2012
          • 5
          • Bangladesh
          Thermaltake Toughpower 750W wired
          http://www.hardwaresecrets.com/artic...r-Supply/369/3
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            The arrangement of the diodes is normal for 2-transistor forward configuration (half wave rectification).
            A working TV? How boring!
            • Maxpayne
              • Jul 2012
              • 5
              • Bangladesh
              What is the role of PNP transistors and TL431 circuitry ???
              • b700029
                Banned
                • Sep 2010
                • 640
                Almost all the ATX PSU schematics I've seen have full wave and center-tapped transformer, like these:
                http://320volt.com/wp-content/upload...tx-circuit.png
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Yes, but that is half bridge. In two transistor forward topology it's impossible to have a center tap and full-wave rectification at the output because the input is single ended, the two transistors switch at the same time, so the magnetic flux in the core only goes one way, hence the output voltage will only go one way as well. You could say the core has a DC bias if it helps you to visualize the situation. Same goes for all single ended topologies: single transistor forward, two transistor forward and flyback.
                  • b700029
                    Banned
                    • Sep 2010
                    • 640
                    Thanks for the explanation.
                    I thought two transistor forward wasn't used at high power levels and half bridge was more efficient?
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Somewhat true, but the marketing in current day ATX PSUs says otherwise. Since the bottom-of-the-barrel Chinese manufacturers have been doing the same outdated halfbridge designs (since that's all they could copy) for over a decade, the high-end PSU companies producing for enthusiasts had to add something new to the marketing, and so they oriented towards double forward.
                      In high power units (1kW+) there's a resurgence of full bridge designs.
                      In the book, "Switching Power Supply Design, Third Edition" there is a comparison made between double forward and half bridge, and ultimately they are pretty much one and the same in terms of power per $$. The number of turns in a double forward transformer is double that in a half bridge - but since the transistors switch the full input voltage not half of it, the current is halved, so thinner wire can be used and the overall copper cost remains the same.
                      Where there IS a difference is in core flux - since the half bridge switches the flux alternately one way and the other, allowable flux density for a given core is practically doubled. In ATX PSUs this makes little difference however, as most if not all ATX transformers are copper loss limited, since they have to deliver high currents. In a higher voltage application, such as a power supply for a large audio amplifier, there may be a difference in favor of the half bridge.
                      In my experience, i've been able to squeeze *a little* more power from a given core size in a half bridge PSU, but the difference is no more than 10%.
                      • b700029
                        Banned
                        • Sep 2010
                        • 640
                        Interesting, so in other words they're taking a topology that's not recommended to go beyond ~500W from most of the references on the web I've found, and pushing it beyond that for marketing reasons. So I guess it's possible to make a real 750W half-bridge too.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Well, i built one that does 650W myself, i don't doubt that with a little bit of care i could squeeze that extra 100W out of it.
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • Nagy Daniel
                            Lowest possible resistance on laptop motherboard rail - Guide Table request
                            by Nagy Daniel
                            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                            So, I generated a table with AI so I can...
                            03-04-2025, 08:24 AM
                            by sam_sam_sam
                            07-01-2024, 06:34 AM
                          • прямо
                            Corsair HX 750W - DC Leakage at 12V Output Rail in Standby Mode
                            by прямо
                            Just received it today from a friend.
                            Auto shutdown by the supervisor IC because of an under voltage condition with 12V output rail (dropped to 10.5V)
                            The same rail also does this when the PSU is in standby mode.
                            https://ibb.co/5TBkg66
                            The leakage keeps climbing at a steady rate but slowing down when it reaches over 800mV or so. I didn't measure exactly at what value it stopped or if it's even stopped at all.
                            What could have caused that?
                            First time I have seen such behavior.
                            3.3V and 5V rails don't have the same...
                            02-19-2024, 09:52 PM
