Help me troubleshoot this power supply. FSP043
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    #81
    Re: Help me troubleshoot this power supply. FSP043
    I'm back on this problem again.. I've noticed that the backlight stays on for as long as I hold a resistor between the 12V rail pin and the BL_ON pin...But as soon as I remove the resistor it immediately shuts down...
    Would it be safe to join the 12V rail pin to the BL_ON pin with a resistor on a temporary basis, so that I can then check the voltages through the circuit... Or would I risk blowing something? What I'm thinking is that if I can check the pins of the CCFL controller to see if it this chip that is causing the shutdown..
    (I've checked the components on the inverter board and I cant find a fault)..
      It acts correctly, the BL_ON must be maintained at around 3~5V for the inverter to be on, 0V = off. If you can get the backlight to come on by using the pullup resistor, it means you Inverter board is OK. That means the main board is not sending the BL_ON signal to turn it on.
      Since now you have backlights, do you see any pictures on the screen? If not, your main board is really bad.
      • JonathanAnon
        • Jul 2012
        • 457
        • Ireland
        #83
        OHHHH, this is contrary to another post.... I was under the impression that just an initial >5V signal needed to be sent to the inverter starting transistor to switch on the circuit, but that THEN the voltage to this starting transistor went to zero.... You are saying that the voltage must ALWAYS be present for the circuit to be on....
        I know that the VGA board is bad, as it would not work with a known good monitor.... I've noticed that when I attached the VGA board to the power board, the 12V rails go to 14.5V, so I assume there is a short somewhere on the VGA board..
        But having confirmed that the inverter is working I will try and source a second hand VGA board..
        • jeanbouc
          • Jul 2013
          Any follow up on this repair....since I am experiencing the same problems with the one I have on my bench repair....thanks!
          • JonathanAnon
            • Jul 2012
            • 457
            • Ireland
            #85
            Hi Jean, I had two of these that were exactly the same... PSUs with bloated caps, and when I replaced the caps on both (and the voltages came back on line) the monitors still wouldnt work... Seems that the capacitor problems on the PSU led to the main board blowing in both cases.. and I havent been able to source replacement main boards as of yet.
            • jeanbouc
              • Jul 2013
              Hi Jonathan....I went ahead and replace the main board and..."voila"....the monitor is working fine....like a brand new....had also replace couples of buldge caps.....wondering what could have went wrong on the main board (video board)...BYE!.....and thanks for your reply...we will keep in touch...
              p.s. I had my 5 and 12 volts from my psu....that is why i started to figure out that the main board was the proble....
              • JonathanAnon
                • Jul 2012
                • 457
                • Ireland
                #87
                It's actually very useful for me to know that, Jean.. Helps to reassure me that I was right, and I love being right.. :-)
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                  After all of...
                  07-13-2024, 08:14 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • penangit
                  Hp v193 monitor power supply board
                  by penangit
                  Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                  I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                  I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                  Steps taken so far:
                  Checked all...
                  02-21-2023, 04:00 AM
                • cmlewis89
                  LG 47LB5DF blown power supply board
                  by cmlewis89
                  Hi folks,
                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                  09-03-2024, 07:50 PM
