Isolator and PWM Control in SMPS (and maybe more assorted questions)
  • Rulycat
    • Apr 2010
    • 724
    There's a lot I don't understand about power supply design.
    I was looking on Hardware Secrets at this page, to do with SMPS:
    http://www.hardwaresecrets.com/artic...Supplies/327/7
    Am I correct in the knowledge that the PWM provides pulses of voltage to the MOSFET, switching it on SOME of the time to reduce the average voltage of, say, 12V, to something lower like 5V (after the caps smooth the pulses of 12V)?
    And the voltage output is compared against the reference voltage to change how often the PWM chip switches the MOSFET?
    What's the isolator for? Is it to prevent the output voltage directly reaching the PWM chip and frying it?
    After next week going to be purchasing this book:
    http://www.amazon.co.uk/Switching-Po...dp_ob_title_bk
    I've not read either edition, so should be interesting.
    Thanks for any help, as always.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Isolator and PWM Control in SMPS (and maybe more assorted questions)
    An SMPS uses a high frequency transformer which is smaller and much more efficient than an old iron-core transformer. Also, as you mentioned, it uses PWM which decreases low-load losses even more. (whereas an iron core transformer will be hot and constantly drawing power with no load)The isolater is to help prevent any high voltage from shocking the user if there is a power surge, or something goes wrong in the circuits.
    Generally iron core transformers are about 50-60% efficient, SMPS transformers can be 80-90% efficient if designed correctly.
    Muh-soggy-knee
      The opto is used for isolation between the Primary AC side and the Isolated DC side of the circuits to prevent electrical shock when the user make contact with the isolated DC side. The SMPS in the primary side looks at the output voltage of the secondary side and adjust its pulse width accordingly, the feedback for this action is coupled through the opto, the output voltage is compared with the ref voltage (TL431 is the most commonly used for the ref) and it will determine how hard to turn on the LED inside the opto which is in the Isolated DC side, the photo-transistor on the receiving side of the opto will conduct more or less based on how much the LED is turn on (it is called current transfer ratio, if you look up the spec of the opto). The opto can withstand up to 2500v before insulation breakdown that will cause the conduction of the current between the AC primary and Isolation secondary side. The secondary side circuit ground is also tied to the chassis, the AC safety ground is also tied to chassis ground to divert any fault current to safety ground.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Linear regulators are typically 30 to 60% efficient. Transformers, be they iron core, or high frequency ferrite (as used in SMPS) are typically 90 to 99% efficient. Regular mains transformers have to be big because of the low frequency needing a large number of turns, and since there are a lot of turns hence a very long wire, then the wire also has to be heavy gauge to achieve low resistance that can carry the current without burning up (remember Ohm's law: P=I^2*R). This alone does NOT forbid the efficiency of a mains transformer to be below 90%, because if you use enough copper the efficiency will be high - the way in which it is manufactured dictates it instead.
        Because iron core transformers are so big, and thus have surface area to dissipate quite a bit of heat, some manufacturers run cores into saturation, or use wire that is too thin, and the losses increase. Microwave oven transformers are the worst offenders. But the transformers found in PA amplifiers for example, are wound to be quite efficient.
        With the use of high frequency transformers like in SMPS, two problems get solved simultaneously. The numbers of turns is drastically reduced, so that a shorter wire is required to do the same voltage transformation. Hence the wire resistance also reduces (since the length is reduced), thus the wire can also be made thinner and still be able to carry the same current it would in a regular mains transformer.
        A working TV? How boring!
        • Rulycat
          • Apr 2010
          • 724
          So is it the switching of the MOSFETs which gives the high Hz?
          Linear power supplies are easy for me to understand - there's just something about switchers which confuses me.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Yes.
            Its feeding the transformer with a high frequency signal. It regulates the output voltage by changing the width of the pulses, which lets more or less energy go into the transformer.
            Muh-soggy-knee
              Another benefit for running at high frequency is smaller capacitance for filter caps.
                TL494 PWM Controller Module Booard to control a SMPS switching power supply are they available for this purpose
                I have seen some board on eBay and Aliexpress but I have not seen any for SMPS switching power board modules I would like to build one if I can not find one that is already made
                Dose anymore known if there is such a module and where would I find some
                While searching this topic on google I found this
                https://www.badcaps.net/forum/troubl...anything/page3
                I have read through this I have some switching...
                09-16-2024, 05:39 AM
              • Yanleb
                LG 60PK550 Logic Control Board EBR63450301
                by Yanleb
                Hi all, I just want to share the repair of my 60PK550-UA TV set.
                The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                C57: 3.30V
                C61:...
                07-20-2023, 12:38 AM
              • dkneyle
                Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                by dkneyle
                This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                02-01-2022, 02:08 AM
              • dicky96
                Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
                by dicky96
                Hi guys
                I have a faulty Xilence ATX PSU here
                The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
                There is another smaller transistor on the primary side C3866 which tests ok
                The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
                There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
                05-11-2021, 07:55 AM
              • harp
                triac phase control 0-100%
                by harp
                Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
                06-02-2024, 09:00 AM
