Dell C400 recharge problem
  • glyn
    • Jul 2006
    I've been googling for help with a Dell laptop power problem and there seem to be some knowledgeble people on this forum. Unfortunately, my problem does not seem to be the same as in the previous Dell thread.
    The laptop is a Dell C400. It works fine with either a charged battery plugged in OR the power adapter but not with both connected at the same time. When the power supply and battery are plugged in the adapter immediately switches itself off. I assume this is some sort of failsafe but I don't know what would be triggering it. The power supply is definitely ok as different supplies all exhibit the same behaviour and I have another working C400
    I've dismantled the laptop but I can't see any loose connections or anything obvious and am not sure how to proceed. It is quite frustating having a fully working laptop which can't recharge its battery.
    Does anyone have any ideas as to what might cause the power supply to shut down? It may help me narrow down the problem.
    Glyn
  • arneson
    • Sep 2005
    • 1267
    Re: Dell C400 recharge problem
    Glyn,
    I'm one of those with the 'other' dell power problem.
    If your still inside be sure to totally clean out fan and rethermal coat proccessor.
    You may carefully resolder power jack or just to be sure you may replace it, it's finicky.
    I want to think your issue is with the bummer dell battery problem, what do you see in the bios? What bios version? page 5? show.
    I've seen, charger none, charger unrecognized, and charger bad.
    Your service tag lookup may also be a clue. The PA series adapters were made by more than one company, Liteon and Delta, which was yours?
    Nothing I say may be helpful because I have not been successful.
    Spent a lot of time and money and have a collection of dead dells.
    Jim
    • glyn
      • Jul 2006
      Thanks for the reply Jim. I'll have a go with resoldering the power jack.
      I've tested it with different power suppliess and batteries because I have a second C400 (ebay purchase after the first one broke) so it isn't a battery or supply problem. I'll have a try with the bios and see what it says.
      Anyone else got any ideas?
      • Rainbow
        • Aug 2005
        • 1374
        The failure is probably in the battery charging circuit. There should be a chip that controls battery charging somewhere - and some transistors and other components around it - I'd check that.
        • arneson
          • Sep 2005
          • 1267
          http://cgi.ebay.com/DELL-Latitude-D4...QQcmdZViewItem
          This is the dock for that lap, It has a seperate power feed and may serve as a work around.
          I don't see a lot of the D44's with problems, like the 1150's have.
          Jim
          • glyn
            • Jul 2006
            Hi again.
            I've had another chance to get inside the laptop but I can't see anything obvious. In fact, I'm not even sure where the chips responsible for the recharging are. Can anyone identify them from the attached picture. The only chip that looks vaguely darker (by which I mean not shiny clean solder) is marked with the red arrow. The text on that chip is 4542 SSAD (delta symbol) w28a. The big chip to the left is just an inductor.
            I've not tried resoldering the power jack since it looks fine and I can run the laptop off of it without any problems. However I may try this anyway if I can convince myself it may be responsible.Does anyone know what each pin on the supply does? On the supply they are labelled +,-,NC and I don't know what NC is. The supply is shutting down because it is detecting a short somewhere. Any tips on locating it?
            Thanks for the tip about the laptop dock. I have a C400 but the principle is the same so I might get one.
            Glyn
            • arneson
              • Sep 2005
              • 1267
              I was able to fix Dell laptop mainboard only after getting a working board next to it for direct comparison.
              Sorry this may not be helpful, but I ended up in total, with two dead boards and two working complete laptops. One to return to owner and one to sell.
              I'm selling toasted boards as well since I bought them as is, not working, just to experiment.
              Jim
              • mutant
                • Mar 2006
                • 123
                I also have one with the charger shutting off. I updated the bios to A12 and in a few weeks it quit charging the battery. I have another c400 mainboard using A11 and have no problems.
                Here is what has been updated:
                The following modifications were made to the A11 BIOS to create A12:
                Issues Fixed:
                1. Fixed issue in which the system continues to report the status
                of the original battery if a battery swap is performed while in
                Standby.
                2. Optimized the battery charging algorithm.
                3. Removed the SMBIOS Type D4h audio tokens since they do not have
                any effect. The audio mode is always "full duplex".
                Look at number 2. I haven't gone back to A11 yet.
                Before it died it sounded like a high pitched whistle and it changed in pitch constantly.
                I have taken it apart and there isn't any loose soldering or other connections.
                I originally thought it was the battery. So I switched batteries. Same problem.
                Lucky for me I don't have to rely on the battery so I have it plugged in all the time running folding@home 24/7.
                So arneson what did you do to fix the laptop board?
                • arneson
                  • Sep 2005
                  • 1267
                  I'd love to give a simple answer to you but it was a costly bitch.
                  Heres the gist of it.
                  Four units, two complete,one smashed screen, one no screen no keyboard.
                  All of these are 1150's, four good batteries, four power bricks not all the same.
                  These laptops did not recognize the power supply even intermittantly but they powered off the battery until dead.
                  The best of the four worked with a brand new power brick, I imediately went to the latest bios and I'm folding and posting on it now.
                  The second successful one needed The jack replaced which I stripped from fourth board, again flashed new bios.
                  The third board only blinks lights, fan runs 2 seconds and will not start. Since the screen is ng, keyboard is ng and main board is ng this is in a junk box.
                  The fourth had a pin hole blown in the power control chip, also in junk box.
                  So bottom line with my dell fiasco was power brick first, resolder jack second,
                  get new bios when you can. Lesson learned, do not let any laptop overheat.
                  Jim
                  • toti24
                    (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                    by toti24
                    dell precision m4600 laptop
                    i7 2760qm
                    8gb ram 750gb HDD
                    intel hd 3000 integraded and nvidia quadro 2000m
                    pleasea bear with me english isnt my language and ill try to be as clear as possible
                    note i live in mexico in a very small town..
                    thank you.
                    laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                    the brick happened when i was installing win 10 using usb.
                    used rufus and officia microsoft.iso
                    it finished copying files from usb...
                    03-06-2022, 08:39 PM
                  • SDNarcia
                    Dell 15R-5521 keyboard problem (KBC?)
                    by SDNarcia
                    Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                    As additional information,...
                    07-20-2024, 10:47 PM
                  • Achille15
                    Dell N5110 problem
                    by Achille15
                    so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
                    03-29-2025, 04:41 PM
                  • masoksian
                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                    by masoksian
                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                    The system does not turn on, there is no post.
                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                    The problem continues in the same way.
                    I tried to turn on the Fn key, nothing came to the screen....
                    02-15-2025, 12:08 PM
                  • MahmoudNasser
                    Dell 7480 problem with freezing during the Windows loading process
                    by MahmoudNasser
                    Hello everyone, I wish you a happy day.
                    I have a Dell Latitude 7480 laptop that has a problem with freezing during the Windows loading process. If it manages to boot up, it becomes very slow and doesn't load anything from the desktop.
                    Device Data
                    Model Dell Latitude 7480
                    CPU:i7-7600U
                    SN:7T58PL2
                    MP PartNumper:CAZ20 LA-E131P Rev:1.0 A00
                    Bios Chips:W25Q128BV
                    The attempts that have been made to solve the problem have not yielded any results.
                    1. Changing the M.2 and M.2 Nvme hard drives.
                    2. Trying...
                    07-09-2023, 05:04 AM
