Trying to learn lcd power supplies
  • electronicsurplus
    • 210
    I am trying to learn how LCD Power supplies and, how to properly diagnose them. I simply cannot understand what to check for when there is no 5volt standby
    Any help would be greatly appreciated
    Thank you
    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
    Help keep these from the landfills
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Trying to learn lcd power supplies
    I learnt much from the data sheets for the control ICs. The standby supply is usually designed around one IC that contains the SMPS controller and power transistor, usually a MOSFET.
    • rievax_60
      • May 2012
      • 897
      • australia
      I have just finished repairing a Philips LCD TV which had no standby 5V.
      I found that the schottky diode at the standby transformer's secondary was short circuited.
      I replaced it with a diode with the same specs, 3A/60V, which got the TV working again.
      When I checked the waveform on the diode's anode, I saw that the negative pulse was peaking at -60V, not good for schottkys so I replaced it again with a 3A/100V part.
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • iMic
        Vintage AT Power Supplies - Selecting Capacitors
        by iMic
        Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
        The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
        02-19-2023, 06:45 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • SkishyIshy
        Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
        by SkishyIshy
        Hey All,
        I have a Sony 65x900f that I purchased cheap because of a no-power issue.
        I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
        I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
        03-17-2021, 11:44 AM
      • AleMonti
        LG 55EG910V - no power and no standby light
        by AleMonti
        I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
        I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
        The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
        After checking the basics I did the following:
        • I measured all voltages and as expected the only active supply is the 3.5V standby. It
        11-04-2024, 05:02 PM
