Enermax Liberty ELT500AWT
  • AP514
    • 9
    second try at this post...1st one blanked out on me so I posted nothing.
    So here is the quick version this time
    I have 3 Enermax Liberty ELT 500AWT --- made 2005
    2 have crapped out on me.
    My computer will not start...used the 3rd good one and computer powers up.
    so not the mobo..
    1) I jumpered power cable to ground( Green to Black). Fans on both came on..
    2) checked Volts on power cable to computer. All get 3.31v, 5.14v, 12.27v ,and -11.86v. ATX power is 12.27V..both PSU's readings are exactly the same
    3) pci cables get 12.27v also.
    4) I put a few fans(Molex connector) on the PSU and ran them...all ports (modular PSU) on both rails ran the Fans.
    5) have looked at most of the CAPs and they look good..no bulges or leaking
    So what other T/S tips can I do to figure out why these seemingly good PSU's are not booting my computer up ?
    Thanks in advance
    AP514
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: Enermax Liberty ELT500AWT
    Try the PSU on a different board. I have a Liberty 500, it's kind of picky about which board it wants to power up with. Also be sure to plug that black/white 3 pin fan plug into the board. I had that issue on some boards where it will not power up without it.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      Weren't those the ones with the tan glue of death?!
      • AP514
        • 9
        the PSU came from that one it was working before....also Fan connector is in board..
        Fast question about that fan connector does the Mobo control that fan or just gets info that PSU fan is connected ? maybe i can jumper it to fakeout the Powersupply if needed.
        think the Glue was an earlier version....No pop or bad smell they just stopped working...
        AP514
        • AP514
          • 9
          OK update took one of the PSU's apart...only see 1 CAP that is bulged at the top only(not sides)...the rest are flat on top almost sunk'n. Not actually sure it is bad but it is in the list of BAD Caps..(whole PSU is probably) CTC 10v 15000uf.
          Cheched for Glue---none seen....
          Im still looking for some serious help in how i can trouble shoot this problem.
          What steps do I need to take to find out what wrong and how to go about it..
          here are a few pic's of my PSU.....Buldge'n top Cap is in far back next to Heatsink
          http://s1262.photobucket.com/albums/ii608/AP514/PSU/
          AP514
          • mockingbird
            • Dec 2008
            • 5484
            Looks like you've got mainly Jamicon/Hermei caps judging by the vent style. Replace all of them, regardless if they are bulged or not. In fact, do a total PSU re-cap.
            • AP514
              • 9
              they are actually CTC's
              • c_hegge
                • Sep 2009
                • 5219
                That's still an off-brand. I'd be recapping it.
                • mockingbird
                  • Dec 2008
                  • 5484
                  Actually, they're probably Hermei... Hermei is the only manufacturer that makes caps with that style, to my knowledge. I think Jamicon is really Hermei and so is "CTC".
                  Also, if you look here, CTC is supposed to have a regular "+" vent, not the "H" vent.
                  Either way, they're junk.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    A few manufacturers use that vent. Jamicon and Hermei are not the same. Their parent company is a group called Kaimei. Sacon also used that Vent. Also, Hermei have been using a T shaped vent, a bit like panny for a while now.
                    • AP514
                      • 9
                      almost all CAPs say CTC but I see 1 or 2 that have(Jand P are same letter) J/PCE-tur on them..in the first pic it is the one w/ the X-top.....the 1 and only Cap that is buldged (10V 1500uf) what should I replace it with ?(Braned name)
                      Any way I guess..I was hope'n to get info on how to T/s this down to finding what part is making it so my Mobo will not power up..Steps or a guide on how to go about it.... doing this more for knowledge than anything else.
                      It would be good to fix it even though I already have a replacement on the way.
                      AP514
                      • Behemot
                        • 4845
                        • CZ
                        I thought Enermax used CEC for these (those are the PCE-Tur if not mistaken), which are mediocre. Hermei sucks hard. I agreee with complete recap.
                        The fan connector should be just for monitoring fan speed, it has only ground and monitoring wires. Though it could not be essential in any way.
                        • AP514
                          • 9
                          OK so what Braned Caps for replacement ?
                          • Behemot
                            • 4845
                            • CZ
                            Samxon, Nichicon, Nippon Chemi-Con (or United CH-C), Rubycon, Sanyo, Panasonic.
                            You can get them genuine here, Samxons from Joe (Big Pope, look at capsmod.net), some Nichicons and Chemi-Cons from Digi-Key, but they usually dont have stock of the specials (3300 uF in D10). Or try luck on eBay.
                            You are interested in low-esr (but not ultra-low, these are for VRMs).
                            • mockingbird
                              • Dec 2008
                              • 5484
                              Thanks for the clarification.
                              Post an entire list of all the caps (Except perhaps the two big primary caps) in the following format (Don't forget the small caps):
                              1) Voltage - Capacitance - Diameter (in mm) - Brand - Series
                              2) etc...
                              • AP514
                                • 9
                                hum.....
                                the CTC ones say 5076 on the side also FM 105*C im assume'n thats the series ? the 5076 or the FM ?
                                I know the Caps that are in there are not the best quailtiy but they have lasted 5+ years. Change'n out cap is no big deal..learned how to sodder at age 12.
                                I know I maybe a bit low on the exp curve on this stuff....and telling me too "Just change out every thing"(CAPs) ,really does not help me learn how to (T/S) Trouble Shoot the problems.
                                So, what im really looking for is some guidance on that part.T/S-ing.
                                AP514
                                • Mad_Professor
                                  A Mech Warrior
                                  • Feb 2011
                                  • 1587
                                  AP514
                                  I think it just senses the voltage. I just know I had three different boards pull that shit on me and plugging that header in did the trick. But I have a 2006 unit.
                                  As for caps, change all electrolytic caps including the small 1uf except the "BIG" 400v/250v cap, it's rare to change those.
                                  If you want to save on caps, you could buy a tester for esr and capacitance and test to make sure they're within specs. It usually requires to remove the component in question for testing.
                                  • AP514
                                    • 9
                                    yes , I was just reading about how ESR goes up in those Caps over time.
                                    and a ESR tester.
                                    Well a new Sesonic PSU has just show'n up (ups guy at the door).
                                    I will mess around w/ pulling out all of the Caps and other things to get access to the Caps....will post back over the next few weeks to let you know how it is going....But feel FREE to post tips on T/S
                                    AP514
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      If they are 3300uF in 10mm Diameter, then use https://www.badcaps.net/store/produc...products_id=56 and https://www.badcaps.net/store/produc...products_id=57 to replace them (depending on the voltage).
                                      • AP514
                                        • 9
                                        Well, just an update I replaced the 1 and only 1 Cap that was buldged(see pic's above and why waste my money recap'n all of them)...pluged PSU into an older Computer and it fired right up....seeing I had already ordered a replacement for it it will sit unused until i need it...
                                        • AJ847.63e
                                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                          by AJ847.63e
                                          Hi Folks,
                                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                          05-06-2025, 10:37 PM
                                          Enermax Liberty ECO 400W [ELT400AWT] - from scraped to serviced
                                          by momaka
                                          Remember this pile of junk electronics I got last year? Well, that's where this Enermax Liberty ECO 400 Watt PSU came from. Like I mentioned, it had cut cables and many bulged caps on the DC output side. I stripped a few cables and did a quick temporary recap with whatever junk (but still reading OK) caps I could find, then performed a basic power test – the PSU passed. Thus, I knew I'd eventually go around to repairing it. One year later and we're here.
                                          First shown is the label below, so anyone reading can see what PSU we're dealing with here.
                                          02-15-2021, 01:05 AM
                                        • eigma
                                          Enermax Tomahawk ETK450AWT PSU Repair
                                          by eigma
                                          A few weeks ago my computer power supply (Enermax Tomahawk ETK450AWT) stopped working. Of course this led me down a reverse engineering and circuit debugging rabbit hole ;-) I also learned about capacitor Equivalent series resistance along the way, and wrote an article about it all. Here are some sneak peeks:
                                          And the full article:
                                          https://github.com/cpatulea/src/blob...awt-psu-repair
                                          Enjoy!...
                                          01-18-2021, 09:14 PM
                                        • LeKowalsky
                                          Enermax Platimax EPM1500EGT random turn on
                                          by LeKowalsky
                                          I'm novice in smps repairs and lurker here also in addition to my preparation I have read Jestine Yong's Troubleshooting & Repairing Switch Mode Power Supplies many times and I cautiously proceeded in small steps a time.
                                          What's on the table?
                                          Enermax Platimax 1500W (EPM1500EGT)
                                          Symptom
                                          A fault is a little tricky here. When plugged into the wall for a first time (i.e. after proper discharge) PSU starts on power button (PS_ON) as expected, runs smoothly with all the voltages in tolerance also shows quite stable operation...
                                          04-14-2020, 08:05 AM
                                        • RukyCon
                                          Modding Two PSUs to Output 12V
                                          by RukyCon
                                          Hello again, this might be a bit of a far-fetched question, but is it possible to modify a 36v and a 48v power supplies to output 12v? Both power supplies appear to use the same topology, they both also have a dedicated 12v winding wired to the control chips, meaning that as soon as i change it so the main output is 12v, then the dedicated windings will not be able to output 12v, meaning it will not start up. However, if i were to then take the main output and tie it to where the dedicated 12v output would go, then it should be able to run fine?
                                          Anyway here is a quick overview of...
                                          02-22-2021, 01:33 AM
