Power Supply Problem
  • rhaivhen
    • May 2012
    • 12
    • Philippines
    Greetings! I have 500w power supply, the problem is when I connect it to the motherboard it doesn't give power to the motherboard nothing happens but when i connect the green and black wire from the power connect it turns on I see the fan running. Can you guys help me? Thank you for the reply and sorry for bad english.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Power Supply Problem
    Test the motherboard on another power supply, there might be a problem on the motherboard.
    Muh-soggy-knee
    • selldoor
      Slow Learner
      • 7870
      What is the make/model of the Power supply
      What is the make/ model of the motherboard
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        When you jump start it, check The voltage of the grey wire on pin 8 (PW_GOOD.
        sigpic
        (Insert witty quote here)
        • 999999999
          • Sep 2006
          • 774
          Often in the beginning of a capacitor problem in the PSU, it can turn on and run with no load but can't stay stable with a load (motherboard, etc, connected) so it shuts off within milliseconds after turned on. Take the lid off the PSU and look for bad (vented) caps.
          • rhaivhen
            • May 2012
            • 12
            • Philippines
            @ben7 I tested it on another motherboard but it still not give power.
            @selldoor the motherboard i used is P4M900-T and MSI 7525. well the power supply i bought is the generic type. it says on the sticker "RISE"
            @ratdude747 I will try that. but what voltage do i need for the result?
            @999999999 okay i will check that. and provide a pictures.
            • selldoor
              Slow Learner
              • 7870
              Hi I see RISE is a common make/label in the Philippines. Did you just buy it new
              is it still under guarantee. Picture of its label and the connectors might help
              • rhaivhen
                • May 2012
                • 12
                • Philippines
                I opened it and i see this. is this the problem? sorry i dont have a HD Camera.
                • rhaivhen
                  • May 2012
                  • 12
                  • Philippines
                  I found a old power supply. It has the same problem. and I saw this. Is this causing the problem? and what part is that? I dont know what it is called.
                  • selldoor
                    Slow Learner
                    • 7870
                    "I opened it and i see this. is this the problem? sorry i dont have a HD Camera".
                    I dont see anything wrong in the picture- try one less close up
                    "I found a old power supply. It has the same problem. and I saw this. Is this causing the problem? and what part is that? I dont know what it is called."
                    The coil part is a Toroid Inductor or Choke. They are usually very stable and
                    do not cause problems. My guess it has been damaged by association with other components possible the ones on the heatsink. Or it has had liquid spilt on it when working.
                    • 999999999
                      • Sep 2006
                      • 774
                      Yes the PSU is damaged, try a different one.
                      • Evil Lurker
                        Warranty Voider
                        • Feb 2011
                        • 454
                        That would be an iron powder toroid. They can be used for power filtering and in boost and buck converters depending on exactly what material they are made of and how the wires are wound around the core. Similar in operation to a transformer but yet at the same time quite different.
                        When a power supply dies as in manner of the picture you have shown, its pretty much ready for the garbage because even if you could find a suitable replacement the power supply is likely to have many more serious problems.
                        • 999999999
                          • Sep 2006
                          • 774
                          About the other PSU you pictured. It's a generic brand (Rise) claiming 600W that seems very low quality. Look at the bridge rectifier diodes, they are 3 amp rated at most. <> 600W
                          Even if the unit is operating within its intended design capability, it may simply not be able to supply sufficient inrush current to get the system rails stable in time on power-on.
                          Your best bet is to abandon both PSU and find something that's better quality.
                          • selldoor
                            Slow Learner
                            • 7870
                            If you still want to look at a repair on the Rise please provide more pictures.
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
                            • JimBanville
                              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                              by JimBanville
                              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                              09-13-2023, 07:21 AM
                            • shadow666
                              How can i connect type c cable to 19v power supply
                              by shadow666
                              hello
                              i have a power supply adjustment like image
                              i want turn on asus vivobook with type c charger
                              i want a connect type c cable to power supply adjustment but type c cable have 3 wire and i don,t know how to connect the cable type c to power supply adjustment
                              please help me to let me know
                              sorry English is not my first language...
                              12-23-2023, 03:32 AM
