Rectifier Input Range
  • synatrol
    • Apr 2012
    • 13
    Hi Badcap members.
    This is a question on switch mode power supplies found in household appliances such as TVs, monitors and computers and the possible problems of sustained over voltage conditions on the rectifier. I have read the FAQ on switch mode power supplies which talks a bout selectable voltage inputs and the affects of connecting 240Vac when selected for 115Vac. But this question is on self sensing switch mode power supplies.
    I live in Australia which has a nominal line voltage of 240Vac at 50 Hz. My house utilizes 3 phases with one phase a few volts higher than the other two phases. During the day it is quite normal to have 260 Vac on one phase and 257 Vac on the other two.
    Looking at all my appliances all have a rated voltage input of 100-240Vac. Doing a quick search on the internet I do find some switch mode power supplies rated for 100-260Vac. I'd be more comfortable if appliances sold in Australia had such an input voltage range.
    Is sustained over voltage something to be concerned about? Manufacturers are selling appliances in Australia with 100-240Vac SMPS so I must assume that they consider possible over voltage as a non-issue. I'm looking to get an in-line UPS for some of my more critical appliances such as computer and monitor which is about a $400 investment. I believe Australia has one of the highest line voltages in the world?
    Thanks,
    James.
  • mariushm
    • May 2011
    • 3799
    Re: Rectifier Input Range
    The rectifier won't have a problem, some have rectifiers that work up to 400-600v.
    In power supplies, the rectified input goes to capacitors which are usually rated for a maximum of 400-450v. The rectified voltage will be Vin x √2 so in your case it would be 260 x 1.4142 = 367 volts. So there should be some room for the capacitors.
    Not sure what would "hate" the 260v input -- maybe the transformers could overheat, or efficiency would decrese.
    My two cents... I think they list so small range so that the power supplies would do well in EMI tests and have an excuse if they fail tests when going over a specific voltage.
    Here in Romania the voltage is 230v but I think the EU standards say all electronic devices should work in the 220v-240v range. The voltages are frequency are pretty stable where I live but sometimes I see 232-235v when measuring.
    It's implausible they would make these power supplies to fail when going even less than 1% over the permitted input range or that they would make special power supplies just for the Australian market.
    • synatrol
      • Apr 2012
      • 13
      Thanks Marisushm,
      The EMI hypothesis sounds plausible for the specifications put on the label. I'm assuming the rectifier diodes would also have a rating well over the peak voltage of 367 Volts as is the smoothing capacitor (400-450 Volts).
      Sounds like I'd need well over 240 Vac before damage may occur. About 5 years ago under voltage was the issue at my house (I've got a 300m main supply cable run). But at some point the main line voltage has increased to the point that I'm getting 260V when I'm not pulling too much current. So I shouldn't be to concerned with the voltage specifications on devices.
      Thanks for your reply.
      • japlytic
        • Oct 2005
        • 2086
        In most switching power supplies, the bridge rectifier at the AC input is rated for at least 600V, as far as I have seen.
          I have seen cheap CFLs with 350V input caps. At 253V (max. nominal in UK), assuming a 1.5V diode drop, that gives 351V across the cap. Although it's barely exceeding the rating, it's still a crap way of doing it. At 260Vac... maybe that might be more of a problem, and add in surges/spikes/transients...
          • Behemot
            • 4845
            • CZ
            That is speaking of crap PSU's. Quality one wont have a problem.
            Also the thing is efficiency rises with voltage so you are lucky man:-)
            • synatrol
              • Apr 2012
              • 13
              That's exactly what I've experienced. I was getting the cheapest CFLs I could find which were still $5 a pop but a lot of them were only lasting weeks.
              • synatrol
                • Apr 2012
                • 13
                So an expensive On-line UPS for clean power may be a bit of an overkill if I'm purchasing devices with very high quality switch mode power supplies. The efficiency of an on-line UPS is a killer. I remember protecting all my equipment on the power side of things to have a lot of it damaged through the CAT5 cabling via the Ethernet switch which in-turn was connected to my ADSL modem which was in-turn connected to my phone line - Ouch.
                I'm probably going away from my original topic but the concern for my equipment was the driver for my original question.
                Thanks for sharing your knowledge.
                • iMic
                  Vintage AT Power Supplies - Selecting Capacitors
                  by iMic
                  Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                  The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                  02-19-2023, 06:45 PM
                  LM358 LM358S-13 Datasheet
                  The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
                  Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
                  10-07-2024, 04:12 AM
                • Steph.hen
                  Bridge rectifier identification part number KPB305G
                  by Steph.hen
                  Hi all, a newby question about a bridge rectifier I'm trying to identify.
                  I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                  08-29-2024, 09:52 AM
                  MP6908GJ MP6908 Datasheet
                  The MP6908 MP6908GJ is a low-drop diode emulator IC that, when combined with an external switch, replaces Schottky diodes in high-efficiency flyback converters. The MP6908 regulates the forward drop of an external synchronous rectifier (SR) MOSFET to about 40mV, which switches off once the voltage becomes negative.
                  The MP6908 MP6908GJ can generate its own supply voltage for battery charging applications with potential low output voltage, and at short circuit output condition, or for high-side SR configuration. Programmable ringing detection circuitry prevents the MP6908 from turning...
                  10-07-2024, 04:07 AM
                • unimatrix93
                  Finding proper replacement rectifier
                  by unimatrix93
                  I'm trying to fix up my battery charger. Where I found a dead schottky rectifier.
                  This is the dead component PTR30L120CTF:
                  PTR30L120CTF datasheet(1/7 Pages) PFC | 30A 120V HPTR Schottky Rectifier (alldatasheet.com)
                  And I have a spare 30CPQ150:
                  30CPQ150 datasheet(1/5 Pages) IRF | SCHOTTKY RECTIFIER (alldatasheet.com)
                  Can I use this diode as a replacement or if not, can you recommend me a proper replacement?
                  I cannot find the exact unit anywhere besides aliexpress and such.
                  Thank you guys!
                  03-05-2024, 09:18 AM
