MP6908GJ MP6908 Datasheet
    The MP6908 MP6908GJ is a low-drop diode emulator IC that, when combined with an external switch, replaces Schottky diodes in high-efficiency flyback converters. The MP6908 regulates the forward drop of an external synchronous rectifier (SR) MOSFET to about 40mV, which switches off once the voltage becomes negative.
    The MP6908 MP6908GJ can generate its own supply voltage for battery charging applications with potential low output voltage, and at short circuit output condition, or for high-side SR configuration. Programmable ringing detection circuitry prevents the MP6908 from turning on falsely at Vds oscillations during discontinuous conduction mode (DCM) and quasi-resonant operation.
    The MP6908 MP6908GJ is available in a space-saving TSOT23-6 package.
    Features
    ● Wide Output Range down to 0V, No Short Circuit Current Flows through Body Diode
    ● No Need for Auxiliary Winding for High-Side or Low-Side Rectification
    ● Ringing Detection Prevents False Turn-On during DCM and Quasi-Resonant Operations
    ● Works with Standard and Logic Level SR MOSFETS
    ● Compatible with Energy Star
    ● ~30ns Fast Turn-Off and Turn-On Delay
    ● ~100µA Quiescent Current
    ● Supports DCM, CCM, and Quasi-Resonant Operations
    ● Supports both High-Side and Low-Side Rectification
    ● TSOT23-6 Package Available
    Applications
    ● USB PD Quick Chargers
    ● Adaptors
    ● Flyback Power Supplies with Very Low and/or Variable Output Voltage
  • johnbeton
    Asus X415EA not charging battery
    by johnbeton
    I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
    So far I measured all the pins on the bq24780s controller with the following result:
    1. ACN = 0.0V
    2. ACP = 19.02V
    3. CMSRC = 18.5V
    4. ACDRV = 23.9V
    5. ACOK = 5.9V
    6. ACDET = 2.57V
    7. IADP = 0.17V
    8. IDCHG = 0V
    9. PMON = ?
    10. PROCHOT = 5.05V
    11. SDA = 3.3V
    12. SCL = 3.3V
    13. CMPIN = 0.47V
    14. CMPOUT = 6.0V
    15. BATPRES = 0.0V
    16....
    05-19-2025, 04:05 AM
  • Dannyx
    Raidmax RX-600 ringing noise and 0ms PG
    by Dannyx
    Good day folks. A former workmate of mine scrounged up this PSU from a client of us. He had a look at it and found a seized up fan which is presumably the main cause of failure. A couple of caps had bulged on the secondary, so it seemed like an easy fix. He replaced them and today I had the honor of doing the test run with him. We attached an ATX tester to its output and plugged it in: it's not quite there yet. While the supply did technically fire up with no pops or fireworks, it's got a couple of issues. The most prominent one is this "ringing" or rather crackling sound it's making...
    07-06-2019, 01:57 PM
    by momaka
    03-12-2025, 03:42 PM
  • c_corr
    Asus P4C800-E VRM issues
    by c_corr
    This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
    This board uses mext ICs and Mosfets in VRM:
    - ADP3180 PWM controller - in 3 phase mode
    - ADP3418 as Modfet drivers
    - High side Mosfets STD38NH02L (from ST)
    - Low side Mosfets STD90NH02L
    Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
    I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
    02-08-2025, 11:59 PM
  • DrewPhillips
    Capacitor Diarrhea - Nichicon PL Series
    by DrewPhillips
    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
    03-02-2025, 10:18 PM
