Stupid freaking mosfets...
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    So i was tinkering with my 555 pwm timer this afternoon and earlier on this morning I had added another 555 timer in bistable mode and made a few adjustments to my resistor/capacitor network. So to check things out visually since I don't have a scope I simply unhooked my connection to the FET's gate leaving it floating while I hooked an LED up to the timer's output. When I got done I just pushed the reset button on the first timer and it killed the power to the second timer. But, the thing is the way I had my circuit wired up I still had power going to the source of the FET.
    I never really gave it a second thought... no voltage to the gate = no power flowing thru the FET. So I go to hop in the shower and when I get out I smell something burning. Damn freaking FET had switched itself back on somehow or something and it was going into meltdown mode. It even melted a hole in my freaking breadboard!
    Well I guess that should be a lesson learned, never leave the gate floating on a FET when the source is hooked to power, even a measly 9 volts 2.5 amp rated wall wart. I reckon it must have leaked a few microamps thru the gate part of the silicon turning that part into a capacitor, and when the voltage got high enough hello short circuit.
    Oh well, there goes $5.60 for the breadboard and about another buck or so for the FET... live and learn I guess... I'm just grateful that it didn't start a fire.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Stupid freaking mosfets...
    Now you know what "high impedance" on the gate means.
    Even static or stray electric fields in the air are enough to induce enough voltage to cause one to turn on.
    9V at 2.5A is 22.5W, plenty of power to cause some thermal excitement.
      master hoarder
      • May 2008
      • 12170
      I think the lesson here learned should be to never leave eletronics (that you are testing) powerd-on unattended.
      • BlackScreen_22
        Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
        by BlackScreen_22
        Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
        Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
        I had no problems connecting mosfets and capacitors,...
        08-27-2024, 12:46 PM
      • Green Probe
        Alienware m15 R5 Ryzen No Power
        by Green Probe
        Hello, I have an Alienware m15 R5 Ryzen, P109f002, with motherboard GDL56 LA-K453P Rev:1.0, Ryzen 9 5900HX, RTX 3070. I got it due to it having liquid damage. I am quite new to chip-level repair, and this is my second post, so please be kind with my incompetence. The charging IC is an ISL95522ah in HPB mode as far as I'm aware. I've been using a schematic for a LA-K455PR10_0525A that is available in the forum, and it seems to match for the most part. If it's okay I can link the schematic, or insert the pertinent page into my post.
        It had some crusty areas that I've cleaned up....
        02-05-2024, 02:46 PM
      • kotel studios
        Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
        by kotel studios
        Finally got time to fix this board up.
        At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
        Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
        04-22-2025, 05:08 AM
      • flerre
        Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
        by flerre
        Hi!
        Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
        No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
        So, could I safely assume all of these 3 mosfets are...
        03-13-2022, 12:14 PM
      • DeanWy
        WD Sentinel DS5100 (NAS) boot issues
        by DeanWy
        I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
        It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
        There...
        07-30-2024, 04:13 AM
